Kennyt Posted September 28, 2015 Report Share Posted September 28, 2015 I understand the valves should be adjusted with engine warm/hot. What should starting cold clearances be since just had head redone? 1 Quote Link to comment
Doctor510 Posted September 28, 2015 Report Share Posted September 28, 2015 .002" tight 1 Quote Link to comment
datzenmike Posted September 29, 2015 Report Share Posted September 29, 2015 I only have the L4 cylinder clearance and the L24 is just two extra cylinders. Same valves, cam lobes and rockers so 0.008" Intake and 0.010" cold. This is fine for a start up, but assumes that the hot setting will be 0.010" and 0.012". Only way to be sure is to re-check when they are hot. 1 Quote Link to comment
Rhino13 Posted September 29, 2015 Report Share Posted September 29, 2015 Look on the bottom side of your hood, there should be a sticker that tells you valve lash. My truck is at my work right now so I can't go check it, but I'm pretty sure hot it's 0.012" int and exh if I remember correctly. Make sure you have cylinder #1 at TDC for 1,2,4,6 then cylinder #4 at TDC for 3,5,7,8 when adjusting. 3 Quote Link to comment
Kennyt Posted September 29, 2015 Author Report Share Posted September 29, 2015 Thanks all for the information 1 Quote Link to comment
datzenmike Posted September 30, 2015 Report Share Posted September 30, 2015 Sorry I gave L series clearances. The Z24 is 0.014" for all valves. (per '84 FSM) 1 Quote Link to comment
Charlie69 Posted September 30, 2015 Report Share Posted September 30, 2015 Hot or cold? Quote Link to comment
datzenmike Posted September 30, 2015 Report Share Posted September 30, 2015 Always hot, this is the FSM recommendation. 1 Quote Link to comment
720inOlyWa Posted October 1, 2015 Report Share Posted October 1, 2015 Look on the bottom side of your hood, there should be a sticker that tells you valve lash. My truck is at my work right now so I can't go check it, but I'm pretty sure hot it's 0.012" int and exh if I remember correctly. Make sure you have cylinder #1 at TDC for 1,2,4,6 then cylinder #4 at TDC for 3,5,7,8 when adjusting. Funniest thing, the underside of my hood was kind of grungy until recently. Somebody had rattle-canned some flat black onto the underside leading edge of the hood in a furtive attempt to delay hood rust, which sort of worked. I yanked what was left of the fiberglass matting attached to the hood, which was disintegrating in hunks anyway. Finishing up the basic clean up, I used mineral spirits to degrease and in no time, discovered the vital engine statistics sticker- in great condition- still ‘on the job’. It is so cool that they put this nice little compact reminder cheat sheet, right where you need it! I totally resto-ed mine, immediately and with great reverence. 3 Quote Link to comment
datzenmike Posted October 2, 2015 Report Share Posted October 2, 2015 Some also have the emissions and hose line runs. 1 Quote Link to comment
Rickie B Posted April 24, 2016 Report Share Posted April 24, 2016 Yes,my 85 720 z24 has all these stickers,says valves .012 hot intake & exhaust 1 Quote Link to comment
Rhino13 Posted April 24, 2016 Report Share Posted April 24, 2016 I recently adjusted mine out to 0.014, although in both of my service manuals and under the hood it says 0.012. It was very clattery but ran about the same, so I put them back to 0.012 and it's much quiter. 1 Quote Link to comment
Kennyt Posted April 24, 2016 Author Report Share Posted April 24, 2016 I adjusted mine to .010. Comp cam tho. Seems to ne quieter a bit 1 Quote Link to comment
datzenmike Posted April 24, 2016 Report Share Posted April 24, 2016 If the valve lash is too wide there is noise and potential damage as the rocker slams into the steeper slope of the cam profile. If the valve lash is too thin there is less time for the valve to seat against the valve seat and this rest time is how the valve cools itself. Heat is transferred to the seat by direct contact. More than that, too little clearance can be reduced even further by sudden heat spikes during driving that can eliminate the clearance even further. If the valve is barely closing it will not only over heat but the valve does not seal the cylinder properly also. Combustion gasses can carve a path and erode the face or seat 'burning' and exhaust valve. On an intake it can cause a backfire under load and in both cases a loss of compression. If you have an after market or stock cam follow the maker's recommendation for clearances. 2 Quote Link to comment
a15egi Posted July 28, 2019 Report Share Posted July 28, 2019 Hi guys. Im having nissan pathfinder/terrano with z24 carb. Setting the valve to 0.30mm (hot) and there is still valve noise when the engine is hot. Should I set the clearance to lower than 0.30 mm? Like 0.25 mm? 1 Quote Link to comment
