The Datsun 1200 SR20/CA thread (if that's okay).
worksnaDELUXE
  • Replies 13
Off the top of my head:
SR20DE long block & tranny
Custom fab'd tranny tunnel
Custom fab'd dizzy (L series/SR)
Custom radiator
Carb set-up (manifold, carbs)
SR20 swap kit (Maddat, or fab one yourself)
Fuel system
Ingnition system(I used MSD 6AL)
Lightned clutch flywheel (optional but recommended)
Over flow tanks x2
Custom plug wiring
Misc..hoses, parts, etc..
Custom or fitted header(My header was custom made by BP in San Jose)
Custom or fitted exhaust (My exhaust was custom made by BP in San Jose)
Front sway bar
My rear end is stock, at 150/60ishWHP my rear end is fine. I'm doing head work next year, at that point I'll be swapping in a H165 Ute rear-end.
Also keep in mind, you'll need suspension as well.
If I think of more, which there is, I'm update this post. All together the swap was about 6K. Not including the car. If a shop does it, probably about 8-9K. Performance Inframe Tuning in Napa, helped with a lot of the swap. They've also worked on my SR20VE 510 back in the day. This swap took me about 2 years, maily because I didn't have all the parts collected that I needed, and it took forever to figure out if I wanted to cut my tunnel.
