Dream510 Posted September 7, 2015 Report Share Posted September 7, 2015 Hey guys, I have a nice pair of mexican tail lights for my 510! I'm looking for peoples opinions on cutting the tail light panel to make them fit. Here's a pic of the lights 1 Quote Link to comment
bananahamuck Posted September 7, 2015 Report Share Posted September 7, 2015 Man those are nice!! You must have paid a ton for those... Make the car your own and cut that sucker Won't you have to straighten that panel first,,, or did you already do that?? Cuz that part of that car that was pretty wavy gravy back there. Quote Link to comment
MicroMachinery Posted September 7, 2015 Report Share Posted September 7, 2015 You should cut the top off and make it a convertible, too. 1 Quote Link to comment
Dolomite Posted September 7, 2015 Report Share Posted September 7, 2015 And go herra frush too. 1 Quote Link to comment
the510keeper Posted September 7, 2015 Report Share Posted September 7, 2015 does it matter what we think, its your car. The taillights are different, its cool seeing different 2 Quote Link to comment
datzenmike Posted September 7, 2015 Report Share Posted September 7, 2015 Hey guys, I have a nice pair of mexican tail lights for my 510! I'm looking for peoples opinions on cutting the tail light panel to make them fit. Here's a pic of the lights If those are for a 510, sure. No different than putting a JDM grill or badges on. If for some other Nissan I wouldn't. Quote Link to comment
Jesse C. Posted September 7, 2015 Report Share Posted September 7, 2015 Do you have the finisher panel that goes between them? They look fine as is, but, that finisher really makes them pop! 2 Quote Link to comment
thisismatt Posted September 7, 2015 Report Share Posted September 7, 2015 Seems a little foolish to take an already hard part to find (stock 510 tail lights/lenses) and modify the car to take an even more difficult to find set fit...unless you have a supply of these? Quote Link to comment
mytoy521 Posted September 7, 2015 Report Share Posted September 7, 2015 Cut it, be a Lil different. It's all good study long study wrong. Quote Link to comment
tr8er Posted September 7, 2015 Report Share Posted September 7, 2015 I don't think you should. It would be an investment of time not comensurate to the reward. Just my opinion since you asked. Quote Link to comment
fritzdixxon Posted September 7, 2015 Report Share Posted September 7, 2015 The great thing about metal is that you can always weld a new piece back in if you change your mind. Quote Link to comment
Dream510 Posted September 7, 2015 Author Report Share Posted September 7, 2015 Thanks for all your opinions guys! The panel is pretty wavy gravy so I'd have to fix that later on I was thinking of making my own panel like McShagger510 did on on his green dime. It looks pretty nice too. Is there any way for the original lights to fit back on there with out any welding or getting a new panel from futo fab? Quote Link to comment
bananahamuck Posted September 8, 2015 Report Share Posted September 8, 2015 Don't let these guys scare you man,,, they are always sending out negative waves.. QTip has a set of these on his yellow 510 and i can't imagine him ever wanting to switch back to boring stock lights cuz that would be a ridiculous thing to do.. Just take your time and measure a thousand times or make a very accurate cardboard template if you have to so the hole ends up the right size.. and your golden. 2 Quote Link to comment
INDY510 Posted September 8, 2015 Report Share Posted September 8, 2015 You also have to drill new holes for most of the studs, and bend the other studs, to get the lights to line up better than Tristin's lights were. I like how James did these lights .. with bends to add more strength than just a cut: 3 Quote Link to comment
KoHeartsGPA Posted September 8, 2015 Report Share Posted September 8, 2015 Hell ya put them on there! Quote Link to comment
q-tip Posted September 8, 2015 Report Share Posted September 8, 2015 OK so when I did mine, only the very outside studs are correct. If you have a gasket for them the use that as a template for the hole pattern you need it put in and for how much of the center you need to cut out. If you don't have a gasket then you going to have to measure each hole placement or make a patter with cardboard or paper, I had no gasket, it was a bitch. Finished product will look like this-ish 1 Quote Link to comment
DaBlist Posted September 8, 2015 Report Share Posted September 8, 2015 Cut, easier to keep clean. Quote Link to comment
q-tip Posted September 8, 2015 Report Share Posted September 8, 2015 I forgot to mention, don't let your buddy line up the template you made for one side but you line up the other.... 1 Quote Link to comment
Dream510 Posted September 10, 2015 Author Report Share Posted September 10, 2015 Thanks for all the help guys, I've decided I'm gonna go for the cut! Really appreciate all the info q-tip,Indy, and nana! Quote Link to comment
q-tip Posted September 11, 2015 Report Share Posted September 11, 2015 And if you have no gasket for the outside I bought some 3/8 or 1/2 adhesive backed weather srtipping, cut to cover the holes and stuck it to the body. Then used an awl heated with a torch it put holes in it where the studs go thru. Quote Link to comment
edekalil Posted September 11, 2015 Report Share Posted September 11, 2015 Those lights do look good when installed, and better with the trim that go's from one side to the other. Quote Link to comment
q-tip Posted September 11, 2015 Report Share Posted September 11, 2015 That's the hardest part to find, been casually searching for one since I installed my lights... Quote Link to comment
Dream510 Posted September 12, 2015 Author Report Share Posted September 12, 2015 The lights came with the gaskets:) Have you thought about making your own garnish Q? Quote Link to comment
edekalil Posted September 12, 2015 Report Share Posted September 12, 2015 That's the hardest part to find, been casually searching for one since I installed my lights...Good luck on your search. Quote Link to comment
