Andy_in_SD Posted September 6, 2015 Report Share Posted September 6, 2015 The 66 I bought for my daughter sat 10 years. The engine was seized solid. It would not budge not matter what, including putting a 5 foot pry bar on the crank and trying to turn it. Common issue with old engines that have sat, this works for push rod or over head. This will work for any car, truck, farm equipment etc... 24 hours later it was turning, and other 2 days and it was running. Here is how. DO NOT SMACK THE CRANK WITH A SLEDGE HAMMER, you'll just break things. Put a bunch of scrap cardboard under your car as a bit of a mess will be created. Mix up at least a gallon of the following (1/3rd each). Marvel Mystery oil, deisel fuel, automatic trans fluid. Pop the oil drain plug and drian everything (look for water in the oil so you know the condition of the head gasket), then put it back in. Pull out the spark plugs (remember to note which high tension goes to what cylinder). Now with a funnel pour the mix into each cylinder. Every hour or 2 refill them as it will works it's way down into the engine. Also load up the top end (valve cover oil filler). Let it sit overnight. NOTE: valve cover gasket is probably fragged, so little bits. Now put a big 'ol 1/2 socket monster onto that crank, slid a pipe over the handle so now the handle is about 4 or 5 feet long (use a strong pipe!). Put your shoulder into it and slowly try to turn the engine. Stuck still beyond movement? Then repeat soaking the cylinders, you may need another 24 hours of that. Once it is turning it will do so very slowly, and be tough as hell. Just keep turning, back and forth if needed. Keep doing this until it turns decently (or at least a pretty good ok). Now, don't put the plugs back in. Put in your battery and hook up a charger. If the charger has "start mode", flip that on. Now turn the motor as though starting it, but only do 10 second bursts with about a minute inbetween to let the starter rest, and the wiring to cool. If it doesn't turn, time to check wiring to the starter (usually a wiring to bendex issue for old Datsuns). As you do this with the starter it will pump oil through the system (super important). After it's winding well, pop the valve cover and crank the engine again. Look to make sure oil is coming up to the valve train (or rocker assembly if a push rod engine). Moves well enough? Well then... put the valve cover back on, hook up #1 plug to it's high tension and lay it on the valve cover on it's side. Crank and look for a spark. No spark? Well, then it's time to chase that back through the distributor, coil etc... Got a spark? Excellent. Now put your plugs back in the head, and hook up the high tensions. Disconnect the fuel line to your carb(s), you don't want to suck crap into the float chambers. Apply starting fluid & fire it up. (if this is helpfull I can continue this further). Here is a video of the first firing for my daughters car after we did all of the above. You can see by the look on her face, the suprise. You can also see the rear of my 70 in the garage behind it. All of the crap blowing out of the tail pipe is simply 10 years of sitting rust in the exhaust, made a nice mess. Roughly 48 hours before this video, the engine would have been pronounced deceased. Once I sort out how to post images / videos I have plenty to share. For now, just a photo bucket link. http://vid304.photobucket.com/albums/nn183/Andy_in_SD/3rdFiring_converted_zpswtlwuvai.mp4 2 Quote Link to comment
datzenmike Posted September 6, 2015 Report Share Posted September 6, 2015 To be that stuck suspect a blown head gasket and water that has sat in one or more cylinders. It may show up in the near future as everything loosens. Not so bad on a pushrod engine. Good write up! 1 Quote Link to comment
Middle man Posted September 6, 2015 Report Share Posted September 6, 2015 Does your daughter like really old guys,she's beautifull. Quote Link to comment
Andy_in_SD Posted September 7, 2015 Author Report Share Posted September 7, 2015 Does your daughter like really old guys,she's beautifull. I'll pass along the compliment. And I'll also see if she will register / join as well. As for liking older guys, that is for her to answer, my guess is "how old". Remember she is 18 so for her "old" probably starts around 22. Quote Link to comment
Middle man Posted September 7, 2015 Report Share Posted September 7, 2015 Got 2 of my own older than that,raised by myself.Just a compliment Dad,good job way to get her involved! Quote Link to comment
shacks510 Posted September 7, 2015 Report Share Posted September 7, 2015 If the rings are that rusted to the cylinders and you bust it loose, the rings and pistons will be destroyed. The rust ridge will most gouge the skirts of the pistons, and the rings will probably be seized in the lands. It'll run, but don't expect it to last long or make any power. I pulled apart an L18 recently that had been improperly stored outside for years. The cylinders were filled with a mess of rusty muddy water. Valves were junk, rings had become one with the cylinders. I eventually got it loose, and was able to bang out the pistons. Needless to say they were junk. Block would need to be honed a ton if it ever wanted a future of being used again. Quote Link to comment
