crewy Posted August 28, 2015 Report Share Posted August 28, 2015 Looking for the distance between backing plate to backing plate on the goon rear end. Quote Link to comment
datzenmike Posted August 28, 2015 Report Share Posted August 28, 2015 Usually it's measured WMS to WMS (wheel mounting surface) so rims and tires fit. Quote Link to comment
Janksun Posted August 28, 2015 Report Share Posted August 28, 2015 I can get you some measurements this afternoon Quote Link to comment
Duncan Posted September 1, 2015 Report Share Posted September 1, 2015 Saw this and remembered this question. WMS to WMS is track width. '68 510 Wagon Rear track: 1260 mm / 49.6 in 1 Quote Link to comment
Lockleaf Posted September 1, 2015 Report Share Posted September 1, 2015 Track width is the measurement from center of tire to center of tire. Only on a car with 0 offset wheels is this also wms. 1 Quote Link to comment
Duncan Posted September 1, 2015 Report Share Posted September 1, 2015 Whoops, you are correct sir. The track width measurement is tire to tire center. The above is a factory spec, and they didn't specify what size/offset wheels were on it. Either way, that is CRAZY-ASS narrow.. Quote Link to comment
crewy Posted September 1, 2015 Author Report Share Posted September 1, 2015 So the width of the rear is 49.6in from hub to hub.Izzo still have the wagon still interested lol let me know Quote Link to comment
datsunfreak Posted September 3, 2015 Report Share Posted September 3, 2015 Either way, that is CRAZY-ASS narrow.. You should measure a Roadster. :rofl: Quote Link to comment
crewy Posted September 8, 2015 Author Report Share Posted September 8, 2015 So you think that the roadster rear end maybe a lil shorter then the goon. Also from what your saying is end of axle to axle is the wms were the the rim buts up to Quote Link to comment
Lockleaf Posted September 8, 2015 Report Share Posted September 8, 2015 Wms = wheel mounting surface. So yes, Where the rim hits the hub. Quote Link to comment
datsunfreak Posted September 9, 2015 Report Share Posted September 9, 2015 So you think that the roadster rear end maybe a lil shorter then the goon. No, I would say it's a shitload shorter. :rofl: I want to say it's around 45" wms-wms? Where the wagon is around 50-51", so... I have a 280ZX rear suspension I was going to put in one of my wagons because it's only 2.5" wider than the wagon axle. For grins chucked it up to the Roadster and that's the day I learned the Roadster axle is impossibly narrow... ^_^ Quote Link to comment
