mrbigtanker Posted August 29, 2015 Report Share Posted August 29, 2015 So I went to see if the PC680 would fit underneath the passenger front seat (E30 sport seats) and it does. So I am thinking that is going to be the final resting spot. Makes it fairly accessible and easy to jump or charge as I can slide the seat forward to get easy access. I'll document the process in my build thread. Thanks for all the suggestions!!!! So like justjoel myself now and another guy are mounting are battery's under the seat,does the 4 door have that same option on the passenger side. If so get with justjoel and he can make you one or make it yourself. These guys can't afford odyssey battery's. And yes you can mount that fucker upside down and all around. That is a damm good battery, I have one myself and will change mines as needed in my other 4 cars.check out justjoel's build thread and you can see the boxes he maid there very nice I know I have one. Quote Link to comment
Laecaon Posted August 29, 2015 Report Share Posted August 29, 2015 So like justjoel myself now and another guy are mounting are battery's under the seat,does the 4 door have that same option on the passenger side. If so get with justjoel and he can make you one or make it yourself. These guys can't afford odyssey battery's. And yes you can mount that fucker upside down and all around. That is a damm good battery, I have one myself and will change mines as needed in my other 4 cars.check out justjoel's build thread and you can see the boxes he maid there very nice I know I have one. He is mounting under the front seat, no box needed... you mounted under the rear seat, you need to make a recessed box for that. I mounted mine under the rear seat as well. Quote Link to comment
mrbigtanker Posted August 29, 2015 Report Share Posted August 29, 2015 He is mounting under the front seat, no box needed... you mounted under the rear seat, you need to make a recessed box for that. I mounted mine under the rear seat as well. Read above again, JustJoel made me a box just like his. Quote Link to comment
GoGoGo Posted August 30, 2015 Author Report Share Posted August 30, 2015 Yup I am mounting under the front passenger seat with the side mount I have. Mocked it up yesterday and everything fit perfect. Seat can still slide back and forth and allow easy access to jump, etc. No box necessary for this setup. 1 Quote Link to comment
uberkevin Posted January 21, 2016 Report Share Posted January 21, 2016 This is a pretty dead thread. But I want more info! How many people are running this battery? As Jrock keeps saying, there is only 170 cranking amps. So it won't start my ka. Someone give me more info here! I'd like to be able to use this battery. The size is perfect to mount under the dash.. I don't have a deck or a sub/amp! Just the cluster and lights. Quote Link to comment
uberkevin Posted January 21, 2016 Report Share Posted January 21, 2016 Then I read stuff like this, that makes me want to tell jrock to suck it :) Quote Link to comment
INDY510 Posted January 21, 2016 Report Share Posted January 21, 2016 I don't know ... :lol: ... it worked for a L16 and 2 headlights Quote Link to comment
uberkevin Posted January 21, 2016 Report Share Posted January 21, 2016 Thanks indy. Lol. Quote Link to comment
Laecaon Posted January 22, 2016 Report Share Posted January 22, 2016 Get a Deka ETX18L. Its only a hair bigger than the PC680, but has more power, and more amp hours. And cheaper. 1 Quote Link to comment
mttam510 Posted January 22, 2016 Report Share Posted January 22, 2016 Deka batteries are solid. Braille used to slap their name on a Deka AGM. I had one in my EVO8. I would opt for the Deka over the Odessey, but that being said, as far as that battery being able to crank a KA....I don't see that being an issue as long as you are running the correct gauge cables Quote Link to comment
datzenmike Posted January 22, 2016 Report Share Posted January 22, 2016 ...and it starts reliably. On a carb vehicle it might not like prolonged cranking. Quote Link to comment
GoGoGo Posted January 22, 2016 Author Report Share Posted January 22, 2016 It's working great so far. Took it on a 1000 mile road trip and no issues. Didn't start the car for a month and it still cranked perfectly. Quote Link to comment
uberkevin Posted January 22, 2016 Report Share Posted January 22, 2016 It's working great so far. Took it on a 1000 mile road trip and no issues. Didn't start the car for a month and it still cranked perfectly. This is what I wanted thanks! And thanks for all the feed back, much appreciated! Deka batteries are solid. Braille used to slap their name on a Deka AGM. I had one in my EVO8. I would opt for the Deka over the Odessey, but that being said, as far as that battery being able to crank a KA....I don't see that being an issue as long as you are running the correct gauge cablesAs far as getting a deka AMG is there anything else I need to know.. a number or something? I do want to keep looking around. Quote Link to comment
Laecaon Posted January 22, 2016 Report Share Posted January 22, 2016 As far as getting a deka AMG is there anything else I need to know.. a number or something? I do want to keep looking around. Read up one post... EXT18L... 340 CCA.... Quote Link to comment
uberkevin Posted January 22, 2016 Report Share Posted January 22, 2016 Oh!! Dude thanks I didn't even see that post! Thanks man!! Maybe Jrock will even jump on board now that he can power his precious amp, sub and stereo. Am able to mount it on its side an shit I'm guessing? Read up one post... EXT18L... 340 CCA.... Quote Link to comment
uberkevin Posted January 22, 2016 Report Share Posted January 22, 2016 Says right there. Nm. Quote Link to comment
Duke Posted January 23, 2016 Report Share Posted January 23, 2016 I have Deka in my car mounted behind the passenger seat. It has done a fine job of cranking my carbed KA over for the past 2 years. If it ever dies I'm going to get a Lithium Iron Phosphate like this one: http://www.amazon.com/gp/product/B00F9LPL5E/ref=oh_aui_detailpage_o02_s00?ie=UTF8 At ~3.5 lbs I'm pretty sure you could mount it anywhere. Here is a picture of my current battery mounting location just for reference. 2 Quote Link to comment
uberkevin Posted January 25, 2016 Report Share Posted January 25, 2016 Thanks for the info guys. Really appreciate it. Quote Link to comment
