620 looking to 720 4x4 leaf spring it
bluebird4200
  • Replies 22
Using the search function, I typed 720 springs onto a 620 and got this.... http://community.ratsun.net/topic/57051-dawas-720-leaf-springs-into-620-swap/ It took me three times longer longer to write this post. Don't be lazy... try it yourself. This swap is well documented and there are more answers.
  • 1 month later...
Just so you know ... you can go back and edit your old posts. For editing the title, (usually sp. mistakes) select Full Editor.
Looks nice. The 4x4 are firmer so less chance of bottoming and the lower center of gravity will enhance handling and braking.
  • 2 months later...
Dayum...Now I dunno what color I wanna paint my truck. THANKS!...
I wanted to go all out on pearls and stuff but dont wanna mess up my FIRST paint job.
Deciding between stock green, red, orange, black, grey, white or even that Taiwanese light blue truck on the internet...
With the last picture you can almost guess a hint of dark blue paint.
  • 5 years later...
from the '84 FSM
2wd.... two curved 7mm thick, one flat and 13mm thick.
4wd.... two curved one 7mm one 8mm thick and flat one 12mm thick
The big difference is the free camber. Hold a string through the center of the bolt holes and measure down to the top of the leaf.....
2wd is 6.34"
4wd is 3.68 ..... much flatter
Spring rate (stiffness, load carrying)
2wd....... 310 pounds per inch
4wd....... 548 pounds per inch
9 hours ago, datzenmike said:
from the '84 FSM
2wd is 6.34"
thanks mike. I guess I bought stock 620 leaf springs
