the510keeper Posted September 27, 2015 Author Report Share Posted September 27, 2015 Its the factory plate, removed so we could replace the damaged areas. Once all the problems areas were replaced the factory plate could be welded back. Getting her on the rotisserie 4 Quote Link to comment
the510keeper Posted October 26, 2015 Author Report Share Posted October 26, 2015 1 more step in the done direction 1 Quote Link to comment
the510keeper Posted November 15, 2015 Author Report Share Posted November 15, 2015 Hired a helper on this one, while I can't seem to get anything in the shop done while working in the Bay area. But my helper is MIA, so Im back at it, took a few days off, to make some more progress. feeling pretty good. Once welding was finished, and possibly from blasting inside out the quarters had a bit of oil caning, so I had to shrink the inside panel. Then float the who;e panel. Looks like a lot of filler but it's simply a thin coat so I wont have to use 20 coats of filler primer. 1 Quote Link to comment
the510keeper Posted November 15, 2015 Author Report Share Posted November 15, 2015 Trying to get the complete car in sealer / primer, no more flash rusting. JAMBS This area needed a little heat, to get it pushed back into line 1 Quote Link to comment
mattyhacks71 Posted November 15, 2015 Report Share Posted November 15, 2015 Mmmmm.....4 door Nice work James Quote Link to comment
Draker Posted November 15, 2015 Report Share Posted November 15, 2015 Look great! Quote Link to comment
the510keeper Posted November 19, 2015 Author Report Share Posted November 19, 2015 And on and on Seam sealed, wish I took more time to remove all the seam sealer b4 blasting doing it afterwards sucks DP40LF always a sure bet 5 Quote Link to comment
sebpv Posted November 19, 2015 Report Share Posted November 19, 2015 what line of ppg are you going with? Deltron? I wanted to but its not compliant with Canada. So Im now using Omni... Quote Link to comment
fisch Posted November 20, 2015 Report Share Posted November 20, 2015 James inspiring as usual. You've educated way more people than you could know. Quote Link to comment
the510keeper Posted December 3, 2015 Author Report Share Posted December 3, 2015 Thanks guys Sanding and sanding and sanding Actually not using PPG for top coat, local paint store does not sell PPG, I get it out of town. Die hard with LFDP40 1 Quote Link to comment
Ranman72 Posted December 3, 2015 Report Share Posted December 3, 2015 many many many people have no idea how much sanding happens when doing body work or how meticulous it can be James you make it look easy and its not :thumbup: :thumbup: :thumbup: :thumbup: keep up the great work 2 Quote Link to comment
the510keeper Posted December 19, 2015 Author Report Share Posted December 19, 2015 Back to the engine bay, got a new welder, what a difference. finished the fucked up holes for the hinges (had some odd standard size bolts on the left hinge). finished all the bumper bracket welded nuts, most the time these don't break off. Good fix is the 17 mm zx top hat strut nut. Opening up the radiator opening for more air flow hammer time and dolly 4 Quote Link to comment
the510keeper Posted December 23, 2015 Author Report Share Posted December 23, 2015 That's a comma dolly wait for it Quote Link to comment
the510keeper Posted December 23, 2015 Author Report Share Posted December 23, 2015 Opened up the strut towers let make some camber or caster or Casper Quote Link to comment
the510keeper Posted January 6, 2016 Author Report Share Posted January 6, 2016 And then there is this, WTF Doner blasted ready to weld in Quote Link to comment
Busta Nut Posted January 6, 2016 Report Share Posted January 6, 2016 .......and another one........ :thumbup: :thumbup: Quote Link to comment
the510keeper Posted January 6, 2016 Author Report Share Posted January 6, 2016 Ready to do some mud work Quote Link to comment
the510keeper Posted January 6, 2016 Author Report Share Posted January 6, 2016 Sealer DPLF40 2 Quote Link to comment
S30Jay Posted January 7, 2016 Report Share Posted January 7, 2016 Your threads are always entertaining and your work speaks for itself! Looking forward to seeing the awesome final result on this one. Quote Link to comment
the510keeper Posted January 14, 2016 Author Report Share Posted January 14, 2016 Sanded and ready for sealer White LFDP48 sealer Sanded again :) Painted 1 Quote Link to comment
fisch Posted January 14, 2016 Report Share Posted January 14, 2016 Smoooooooth! Quote Link to comment
Anonymous Waffle Posted January 15, 2016 Report Share Posted January 15, 2016 Beautiful work so far!! Quote Link to comment
Draker Posted January 15, 2016 Report Share Posted January 15, 2016 Looks great! Quote Link to comment
S30Jay Posted January 16, 2016 Report Share Posted January 16, 2016 Just like new. When I used to do collision repair I would use primer over bodywork, then block it and paint it. Sealer was used for areas where I broke through the primer while sanding, or if I was painting over an unknown type of finish to keep the paint I spray from reacting with it. Curious why you chose to sealer that trunk lid vs. Priming it? 1 Quote Link to comment
