bonvo
bonvos 77 k5 the big bitch
then i worked on it a little here a little there as time allowed usually 1 afternoon a week
build will yield 9.5:1 compression
cam specs are as follows
Duration Advertised 278° Intake/288° Exhaust
Duration @ .050'' 204° Intake/214° Exhaust
Lift @ Valve .420'' Intake/.442'' Exhaust
Lift @ Cam .280'' Intake/.295'' Exhaust
Lobe Separation Angle 112°
Intake Centerline 107°
Intake Timing @ .050"  Open 5° ATDC Close 29° ABDC
Exhaust Timing @ .050"  Open 44° BBDC Close 10° BTDC
Vacuum @ 1000RPM Idle 14"
based on similar builds ive seen as well as engine masters building a slightly tamer 350 this should make anywhere from 370-400 hp and 400-425 tq any bets on how long the turbo 350 lasts?
Share this post
Link to post
been waiting for a dry weekend to drop it in but i did keep working on the light wiring
not done yet a few more wires to run then wrap it all up nice and neat
Share this post
Link to post
Nice motor. :devil:
Share this post
Link to post
here we go last weekend i finally got down to business
  • Like 3
Share this post
Link to post
home stretch tomorrow carb gets finalized prime the oil system stab the distributor run plug wires and turn the key!
  • Like 4
Share this post
Link to post
also finished my offroad lights
low beams
high beams
fogs
leds
all on
  • Like 3
Share this post
Link to post
Those are some bright lights.
Share this post
Link to post
not bad for amazon 36 dollar specials and you get 8 of them i only used 6 of them on the truck i will definitely buy them again
Share this post
Link to post
Got a picture of the LEDs? from the front.
Share this post
Link to post
actually i do
Share this post
Link to post
i have an ear to ear smile right now little worred about the cam since i had to shut it down twice due to plug wires melting but all seems ok now just re tq the heads and tune it
Share this post
Link to post
  • Like 3
Share this post
Link to post
Nice man! She sounds real good.
Share this post
Link to post
now if i can just figure out why the trans doesnt wanna shift lol i think its either the kick down cable not being adjusted right or the vac modulator on the trans has a kinked line
Share this post
Link to post
I think it has something to do with taking the truck apart and putting it back together :fu:
Sounds fucking great :cool:
Share this post
Link to post
it was the kick down cable not being adjusted right
Share this post
Link to post
Just ran across this build sweet!
Share this post
Link to post
new taylor wires almost a perfect match for the body color
other then minor tuning (still more to do need a new vac diaphram for the dizzy) just been enjoying the truck some random shots ive taken
someone needs to throw rosie some mardi gra beads
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
