Phixius Posted May 24, 2015 Report Share Posted May 24, 2015 Ive got beebani UCA. All d21 hub, spindle, brakes, LCA. And a 620 crossbar. Pictures... The 620 crossbar has space on the inside. Do you just add washers? Or is a 720 crossbar wider shoulder to shoulder? Next pic is the 620 bar in with hardbody bar above it is too wide bolt pattern and length and then the stock 521 bar. Way too short. Second question. I got new moog balljoints for this and the new joint doesnt press in. Its way too sloppy. Is it the right style? Quote Link to comment
Phixius Posted May 24, 2015 Author Report Share Posted May 24, 2015 Solved the balljoint issue... still stuck on the cross bar... And whats the bolt size for the 620 cross bar? Quote Link to comment
