plnfixr320 Posted May 25, 2015 Author Report Share Posted May 25, 2015 That's what we did Jester. The cab was only pushed back to get the engine mounted into the frame to mark the firewall for cutting. The Toyota frame is an 84 and the Toy radiator is to tall for the 521. 1 Quote Link to comment
Jester Posted May 25, 2015 Report Share Posted May 25, 2015 What about the stock 521 radiator? Maybe try that. no sense spending money you may not have to, 2 Quote Link to comment
plnfixr320 Posted May 25, 2015 Author Report Share Posted May 25, 2015 As the the first post shows, all we got was the cab and bed hence why I was asking if anyone had a junk 521 radiator that we could use just as a mock up component. 1 Quote Link to comment
plnfixr320 Posted May 25, 2015 Author Report Share Posted May 25, 2015 With the EGR delete plate on the back of the head we got the engine in the frame. We will have to cut to get the cab back forward so the front axle isn't outrunning the rest of the truck. The weekends progress was hampered a bit by a bit of a gap. The input bearing for the rear case is 0.010 bigger than the dual case adapters machined opening. I am gonna have to call trail-gear tomorrow. 1 Quote Link to comment
plnfixr320 Posted May 27, 2015 Author Report Share Posted May 27, 2015 Just a quick status update. Found out that the rear case being from an early round headlight truck has a slightly different spline profile. The guy at trail-gear said to just swap it with the forward case and all will be fine. So now we have two cases to completely tear down and rebuild. 1 Quote Link to comment
plnfixr320 Posted May 28, 2015 Author Report Share Posted May 28, 2015 Note the different spline profiles Front case Rear case 1 Quote Link to comment
oldskoolvws Posted May 29, 2015 Report Share Posted May 29, 2015 VW Rabbit or Honda Civic Radiator. If it doesn't fit with the fan, take off the fan and run either slim electric or move to push fans and put them in front of the radiator. I removed my clutch fan from my 22RE and run a Nissan Quest 2 speed electric fan with a Volvo 2-speed relay with BMW two temp sensor. Works like a champ. Also, change your themostat to the two-stage version. Another great mod for cheap. While the 22R is out, remove the front timing cover and replace the plastic chain guides with metal or you will be hating life later. I promise you. Might as well do the timing chain as well. If you want a good deal on good parts Toyota (non-OEM) hit up engnbldr.com (Ted). Use much of his stuff with no issues at all. I run his 268 cam in my daily. Too bad you didn't find a 20R and use the 22R head. Thats the hotter ticket. I have a spare 22RE head with 2mm over sized valves and port / polished but that's a lot of work to make it function. 3 Quote Link to comment
plnfixr320 Posted May 29, 2015 Author Report Share Posted May 29, 2015 The 22r is an early tall deck one, we are gonna do a full rebuild on it. I thought the trick was the smaller chamber 20r head on the early 22r for higher compression and some HP. I been wrong before. We were already planning on electric fans for better slow speed high rpm trail rides. Just looking at the front end I can't imagine there's room for pusher fan/s. If someone has done it please point us in the direction. The Civic Rad is a good tip, that should be easy to find in a junkyard. 1 Quote Link to comment
plnfixr320 Posted May 31, 2015 Author Report Share Posted May 31, 2015 Got the input shafts swapped today. Then we stabbed the dual cases in and got the cross member installed. Since the sun was still up we cut the fire wall and trans tunnel open to move the cab forward. Finally we mounted the steering box. Looks like we have a country mile for a radiator and fans now. 1 Quote Link to comment
plnfixr320 Posted June 4, 2015 Author Report Share Posted June 4, 2015 At some point someone had bugger welded some bucket seat brackets to the floor. So they had to go. The stock bench went in and the front case shifter clears. The rear case will require either going to buckets or some trick twinstick engineering. The super cool purple and orange vinyl is hard to beat. The steering shaft lined up fairly good. The axle centerline is 3" forward of the wheelwell center. 1 Quote Link to comment
Jester Posted June 4, 2015 Report Share Posted June 4, 2015 That should work pretty nice with the shackle reversal. I like how the Toyota engine sits a lot further behind the front axle center. Datsuns sit a lot closer to center. Stands to reason why you had to cut the firewall. It should wheel awesome though! Nice work guys, KEEP IT UP! :thumbup: 2 Quote Link to comment
Z chopper Posted August 6, 2015 Report Share Posted August 6, 2015 I told him that I will not build his truck. I will however match every second he works on it 100%. He should end up with something he knows inside and out and is proud of. now that is being a DAD. For a seat solution track down a late 70s/early 80s Datsun, Mazda or Toyota truck bench seat as they normally have a notch in the middle of the seat for the shifter clearance. 2 Quote Link to comment
plnfixr320 Posted August 11, 2015 Author Report Share Posted August 11, 2015 We are gonna have to look into buckets most likely. The rear case shifter is another 7 inches back or so. 1 Quote Link to comment
plnfixr320 Posted August 11, 2015 Author Report Share Posted August 11, 2015 We are missing the two metal strips that mount the instrument panel in the dash. Sadly the local yards don't have any 521's. Any suggestions on where to find them on the internetz or another model that would be close enough to look for in local yards? 1 Quote Link to comment
Charlie69 Posted August 11, 2015 Report Share Posted August 11, 2015 Are these what you are talking about? These belong to my 520 but I am sure I have another pair. PM me your address and I will send you a pair. 3 Quote Link to comment
plnfixr320 Posted August 12, 2015 Author Report Share Posted August 12, 2015 Yes those things Charlie. PM inbound 1 Quote Link to comment
NissanNut Posted August 17, 2015 Report Share Posted August 17, 2015 Nice build project. I wish I could get my 14yr that motivated. Rebuilding a 95 2wd for him. But he wanted my old SAS 93 D21. 2 Quote Link to comment
Jester Posted August 18, 2015 Report Share Posted August 18, 2015 Nice build project. I wish I could get my 14yr that motivated. That makes two of us. If I wanted him to build a bicycle or a skateboard he would be all over it. :rolleyes: 2 Quote Link to comment
gene knight Posted August 18, 2015 Report Share Posted August 18, 2015 nice build thread. if you are in need of some 521 parts let me know 2 Quote Link to comment
Charlie69 Posted August 20, 2015 Report Share Posted August 20, 2015 I will be at the SWDP Barbecue On Sunday. I hope you and your dad can make it. If possible bring your project. I am bringing my project. We love to see any Datsun. Quote Link to comment
flatcat19 Posted August 20, 2015 Report Share Posted August 20, 2015 Too cool. I'm digging it. 1 Quote Link to comment
Charlie69 Posted August 27, 2015 Report Share Posted August 27, 2015 Ryan and Phil it was great to meet you and talk Datsuns at the SWDP Barbecue. I will dig out a glove box handle and latch for you. 1 Quote Link to comment
plnfixr320 Posted August 29, 2015 Author Report Share Posted August 29, 2015 It was great talking with you to Charlie, we learned a lot down there chatting with everyone. The people were all so nice. 1 Quote Link to comment
Z chopper Posted August 31, 2015 Report Share Posted August 31, 2015 Nice build project. I wish I could get my 14yr that motivated. Rebuilding a 95 2wd for him. But he wanted my old SAS 93 D21. That makes two of us. If I wanted him to build a bicycle or a skateboard he would be all over it. :rolleyes: I could maybe wrangle up some cattle prods, they should do the trick. :rofl: 2 Quote Link to comment
Anderson521 Posted July 14, 2016 Report Share Posted July 14, 2016 What's the latest with this build, so sick 1 Quote Link to comment
