paradime Posted December 28, 2015 Report Share Posted December 28, 2015 I don't think a KA vs. SR would really matter on this track. Suspension and driver is much more critical. I'm running stock brakes, bottomed out suspension and shit tires. Still eating STI's and lots of other fast cars. I did grow up in the hills and practiced my driving lots! Wait a minute. Did you just say the only thing wrong with my car is me? :huh: Yah, on second thought, don't answer that. 2 Quote Link to comment
Josh K. Posted December 30, 2015 Report Share Posted December 30, 2015 I made 1.25" (31.75MM for you Jeff) bump steer spacers for my car. With 15x8's I needed a 0.125" wheel spacer to clear the tie rod end. 1 Quote Link to comment
Icehouse Posted December 30, 2015 Author Report Share Posted December 30, 2015 I made 1.25" (31.75MM for you Jeff) bump steer spacers for my car. With 15x8's I needed a 0.125" wheel spacer to clear the tie rod end. My T3 spacers are the same thickness. Check out these screen captures. Even with LCA's parallel to the ground the roll center is still basically subterranean. We are thinking about doing what the BRE dudes did. Raising the inner LCA pivot an 1" then lowering the outer tie rod enough to fix the bump steer. First we are going to see what it does on the computer. what the BRE dudes did. See how the tie rod arm swoops down. I just imagine that it narrows the usable good bump area to a pretty small margin. 6 Quote Link to comment
q-tip Posted December 30, 2015 Report Share Posted December 30, 2015 It looks like they had the sway mounting under the control arm, that would surely fix the sway bar tc rod interference. That spindle looks super high from the arm too, those guys did some work. Quote Link to comment
thisismatt Posted December 30, 2015 Report Share Posted December 30, 2015 I see a straight tie rod, straight T/C, and a goosenecked steering knuckle Quote Link to comment
dscottdatsun Posted December 30, 2015 Report Share Posted December 30, 2015 I see this putting the tie rod below the balljoint & T/C at an upward angle. Would there be an advantage to mounting the T/C on the bottom of the lower control arm? What would be the metallurgical impact from using a torch to bend the steering arm? Isn't the use of the RCA's similar to putting lowering blocks in a leafspring suspension? Quote Link to comment
Icehouse Posted December 30, 2015 Author Report Share Posted December 30, 2015 It looks like they had the sway mounting under the control arm, that would surely fix the sway bar tc rod interference. That spindle looks super high from the arm too, those guys did some work. Yeah I want to build a sway bar for under the LCA's for sure! I see a straight tie rod, straight T/C, and a goosenecked steering knuckle That was the word I was looking for "steering knuckle"!!! Thanks Mat! I see this putting the tie rod below the balljoint & T/C at an upward angle. Would there be an advantage to mounting the T/C on the bottom of the lower control arm? What would be the metallurgical impact from using a torch to bend the steering arm? Isn't the use of the RCA's similar to putting lowering blocks in a leafspring suspension? Instead of bending it I'm just going to machine one and also make it quick steer. yeah RCA's are exactly that. If only I could make them 6" tall :) Quote Link to comment
q-tip Posted December 30, 2015 Report Share Posted December 30, 2015 The mounting point is all you really need to change to get the sway bar under the lca, a piece of steel twists the same whether it's turned slightly up or slightly down. Each end just needs to be connected to each lca for it to still be a sway bar. Quote Link to comment
Icehouse Posted January 6, 2016 Author Report Share Posted January 6, 2016 Built new sway bar brackets which allowed me to sand the rubber part thinner which raised the sway bar. At 16 degress of LCA angle the tire hits the frame. Raising the sway bar and adding longer end links should be enough. Just in case I'm going to build taller bump steer spacers (I hate calling them that!) Here are some pictures. First modify the model Sam made for his car. Which I modified twice but only got pics of the second version but built the fisrt version... Drawing version 2 even though I built version one. Which is a damn good thing it barely fit! Programmed in my mill Machining. installed with LCA at max compression. I don't know what happened to the bushing. I only sanded the one side. Maybe the heat messed with it. 5 Quote Link to comment
mklotz70 Posted January 6, 2016 Report Share Posted January 6, 2016 Mmmmm.....milling at home!!! :) So sweet!!!! Thanks! Quote Link to comment
Busta Nut Posted January 6, 2016 Report Share Posted January 6, 2016 :thumbup: :thumbup: :thumbup: :thumbup: 1 Quote Link to comment
dscottdatsun Posted January 7, 2016 Report Share Posted January 7, 2016 love the new sway bar brackets!!! Uber bling :thumbup: 1 Quote Link to comment
carterb Posted January 9, 2016 Report Share Posted January 9, 2016 Good luck today Jeff. Be sure to kill those new tires, not the cones! We need more video! 3 Quote Link to comment
Icehouse Posted January 10, 2016 Author Report Share Posted January 10, 2016 First place in RWD!!!!!!!!!! Second fastest time of the day!!! An new AWD turbo porsche got me by just a little he was able to shift to 4th before the finish line! The last straight away allows the high HP guys to make up some time. HHHMMM maybe I need a turbo! I seriously couldn't believe the difference having suspension travel and nice tires made! The best part was all the dudes who actually came up to ask how I was so fast and what they were missing. They couldn't believe I was SECONDS ahead of there AWD Skyline or STI swapped subi, I even beat a twin turbo viper with slicks, and a track only V8 rx7 with 12" slicks. Really I couldn't believe it either! There were over 40 cars and almost every one was nice. I think I was the only car with rust on the outside haha. I'm super happy I didn't mess up my car. One guy hit the wall and another bent some suspension going off track. It's an intense place to race. O and yes the front tires rub. Just keeps them nice and heated for next laps. :) 13 Quote Link to comment
q-tip Posted January 10, 2016 Report Share Posted January 10, 2016 Congrats! It's called driver skill, knowing when and how is more important than horsepower, just ask John Morton. 2 Quote Link to comment
Trophy24 Posted January 10, 2016 Report Share Posted January 10, 2016 Way to go Jeff! 1 Quote Link to comment
paradime Posted January 10, 2016 Report Share Posted January 10, 2016 Way to represent the big D Icehouse. If it takes an AWD turbo Porsche to hang with a RWD 510, than wouldn't it be more honorable if the pencil dick driving his store bought Cayenne, or Carrera 4 just bought his first place trophy straight from the store as well? He may have the trophy, but you won that race, and he knows it. Love the pict! 1 Quote Link to comment
Charlie69 Posted January 10, 2016 Report Share Posted January 10, 2016 Congrats Jeff. 1 Quote Link to comment
volkswagner Posted January 10, 2016 Report Share Posted January 10, 2016 So much fun to watch! Seeing that little 510 tear it up through the corners was quite the sight. Really shows what these cars are capable of with a competent driver. 2 Quote Link to comment
Ranman72 Posted January 11, 2016 Report Share Posted January 11, 2016 nice work its all about the driver and set up being smart and smooth awesome job you beat out some nice rides :thumbup: :thumbup: :thumbup: :thumbup: 1 Quote Link to comment
Icehouse Posted February 25, 2016 Author Report Share Posted February 25, 2016 Another win! Okay turns out they stop official timing at 7:00... Of coarse my killer time happened at 7:04.... I'm cool with second in RWD though. It's just a blast driving like a maniac! I had trouble with the new coarse so it took me a little longer to get a really good time in. My problem was all the previous events the slalom was every other cone. This event it was 2 cones to the right, one to the left, 2 to the right, 3 to the left... My brain was stuck in every other..... haha. So lets just say I had a couple laps of some serious drifting changing my mind mid corner haha. My favorite part of the race was when I left. They always have a volunteer sitting next to the exit stopping cars and asking if they turned in their transponder. The volunteer this time was a old retired aged lady. She had me stop and came up to the window and asked if I turned in the transponder, which I replied "yes". She then noticed the trophy in the passenger seat. She ask with pure amazement "did you win one of the races" while looking at my car with a puzzled look on here face :) It was very obvious she was in disbelief a rusty old Datsun could win one of the events :) T 10 Quote Link to comment
Draker Posted February 25, 2016 Report Share Posted February 25, 2016 Hell yah! Congrats! 1 Quote Link to comment
q-tip Posted February 25, 2016 Report Share Posted February 25, 2016 Wolfman, racecar driving legend?..... 1 Quote Link to comment
carterb Posted February 25, 2016 Report Share Posted February 25, 2016 Have you figured out which tool(s) in your garage you are going to give up to make room for all the trophies? 1 Quote Link to comment
