5150 Wll Posted May 9, 2015 Report Share Posted May 9, 2015 When I got my wagon the fuel tank was removed/bad. I got a new tank and I'm putting it back in with new vent hoses and I think i'm missing a piece. Is there supposed to be a rubber section that goes onto the tank filler and then to the filler neck attached to the body? Or is the plastic end of the filler tube supposed to slide over the tank filler tube? I'm pretty sure i'm missing a piece...... Quote Link to comment
Just Joel Posted May 13, 2015 Report Share Posted May 13, 2015 This ^^^^ there is a plastic elbow that connects the filler neck to the tank. It has a bulkhead flange that bolts to the inner rear fender as well 1 Quote Link to comment
mrbigtanker Posted May 14, 2015 Report Share Posted May 14, 2015 I have that hose Joel. A new NOS one. Quote Link to comment
Laecaon Posted May 14, 2015 Report Share Posted May 14, 2015 If the hose is still there, but short, there is a trick with a hair dryer to soften it and elongate it back to size. Its a Dime Quarterly topic... http://community.ratsun.net/topic/46070-wagon-fuel-fill-what-am-i-missing/ Quote Link to comment
5150 Wll Posted May 18, 2015 Author Report Share Posted May 18, 2015 I think the heat gun trick should be the ticket. I got it over the tank inlet but it still seems a little short. I'm going to heat it a little more with my heat gun farther up and see if I can stretch it down a little farther onto the inlet. Thanks guys!!! Quote Link to comment
