blueribbon Posted May 3, 2015 Report Share Posted May 3, 2015 I heard that the 280Z transmissions are a great fit for the 610 because you don't have to modify the driveshaft however, will I have to cut the shifter hole to allow the Z transmission to fit? Quote Link to comment
blueribbon Posted May 3, 2015 Author Report Share Posted May 3, 2015 I do believe it is the B series Transmission. Quote Link to comment
datzenmike Posted May 3, 2015 Report Share Posted May 3, 2015 Well you tell me.. The distance from the front of the zx 5 speed to the very center of the shift mechanism is 74cm.... that's 29 1/8" for all you Americans that only have inch tape measures. :lol: If all you need to do is a little trimming for a 5 speed.... that's pretty darn good. Quote Link to comment
MicroMachinery Posted May 3, 2015 Report Share Posted May 3, 2015 You have to open it up slightly. Check my build thread "TURTLE POWER" Quote Link to comment
Zeusimo Posted May 4, 2015 Report Share Posted May 4, 2015 I Didn't Do Anything To Fit My 280ZX Trans Quote Link to comment
bonvo Posted May 4, 2015 Report Share Posted May 4, 2015 If the car was originally manual trans its a simple bolt it in and go swap Quote Link to comment
MicroMachinery Posted May 4, 2015 Report Share Posted May 4, 2015 If the car was originally manual trans its a simple bolt it in and go swap 1 Quote Link to comment
