'62 Falcon Econoline
As a painter myself, if someone pulls a part and masks it off, then cleans it with wax and grease remover, that would get me much closer to priming and painting it.  Just sayin'......  :thumbup:
ok, I need to convince John to go in and paint the insert area purple for me.
  • Replies 626
WTF is going on with the site?  If this is the new look, I'm leaving.
*edit* Ok, the look bugs, me but at least everything is working again... unlike when I was in earlier.
Edited by dimlight65
So for the cooling issue, Tim has decided the plan is to install an engine driven fan. We got one of the "race car" fans that moves a ton of air. This required the use of a 2" spacer on the fan, as well as moving the radiator back 1"
37254360_1784650434947406_57859075972949
Which meant cutting an inch off the top blockoff panel he made as well...
37238290_1784650484947401_89768256755204
You can also see in that photo the nifty prop rod he made for the doghouse lid...
We are currently pulling the transmission to replace the clutch. After that gets sorted, we will give it a drive to see how the fan does. We are expecting to need a shroud as well, but hoping we will get lucky and not need it...
the new fan looks like it can keep things cool. Maby a thermocluch for it? The BMW I had used 2 electric fans up front and one thermcluched can on the engine. Kept it nice and cool. They usualy overheat when the one on the engine fails. Volvo 700/900 series use cluch on  a fan.  Also can you get a shroud or what yo call it aroud the fan. It will help move a lot of air.
Edited by Aibast
On 7/24/2018 at 11:22 PM, Aibast said:
the new fan looks like it can keep things cool... Also can you get a shroud or what yo call it aroud the fan. It will help move a lot of air.
We are planning a shroud eventually, but we are going to try it without just to see if this is enough.
On 7/2/2018 at 3:27 PM, dimlight65 said:
I need to go in and paint the insert area purple... ok, I need to convince John to go in and paint the insert area purple for me.
Done.
38289152_1817199861692463_56763058859414
On 7/6/2018 at 2:53 PM, dimlight65 said:
I might have a look at the transmission to see how big an ass-whip the clutch job is going to be as well.  We'll see.
Transmission is now out, and it was really quite easy. Took the flywheel to the machine shop to get it refinished. Should be picking it up today.
Unfortunately, the clutch Amazon sent us was a 10" clutch, and we need an 8.5" clutch. ?
After doing some detective work, some online sources seem to believe the 10" clutch is what the '62 Econoline van used originally. There is no way that big a clutch/flywheel would fit into this tiny transmission. Apparently the '64-67 Mustang with a 200ci engine (what our engine is) used the 8.5" clutch so we ordered one of those and it should be here Monday/Tuesday. I honestly think this 10" clutch must be for a V8, not a straight 6...
Flywheel back and looking sharp, and the 8.5" Mustang clutch fits well...
38828291_1828099937269122_16982099855713
That and the transmission should go back in Saturday...
Tim has been reading up on making more power with this engine and the consensus seems to be getting colder air into the engine, not having it suck air from the "hot box", is the path to more power. Tim got an air box from a 280Z and made a bracket for it to bolt to the bottom of the van...
38875476_1828099943935788_68506824272290
Got that installed and started looking at how to connect that to the carb. Tim got a hat and some piping and...
38849788_1828099980602451_83489568447434
While he was doing all that, I disassembled and cleaned the driveshaft. Then installed new u-joints and painted it...
38769171_1828100010602448_38008784888109
This driveshaft has the smallest tube I have ever seen. And wee tiny u-joints as well...
  • Like 3
  • 4 weeks later...
Tim made a thing!
He didn't want the spare tire inside, and we didn't have room under the van, so he made a neat extension to the trailer hitch receiver that holds up the spare...
large.20180925_153924.jpg.a62d38f2be6cf2
It has a pivot on the bottom, so you just pull a pin and...
large.20180925_153813.jpg.33800a4f961b63
And the tire is just low enough to open the door...
large.20180925_153803.jpg.21ec74f850845f
I like it...  ?
large.20180925_183412.jpg.e9b0a19bb5e2a3
  • Like 5
On 10/10/2018 at 3:49 AM, goes2fast said:
What are the 3 holes for?
Speed holes?
If you look at the pic with it in the up position, the steel bar it rests on has three corresponding holes in it. Two will be used if it needs to be firmly attached. For now, we're just gonna use some zip ties in those holes. The third hole is for the hood prop we made.
Edited by datsunfreak
  • Like 3
  • 2 months later...
Tim has been driving it a bit, racking up some miles, looking for things that need addressing, and we found a few...  ?
The small VW mirrors were just not getting it done, so we swapped to these...
large.20181208_175040.jpg.43309f362f47f6
That made a big difference in visibility. ?
As you can see in that pic, we also completely disassembled the front door guts. They were rattling sooooooooooo bad. We are now in the process of painting the interior side of the doors. Once that is finished it will go back together will all new rubber bits for a (hopefully) rattle-free drive.
  • Like 4
Well, I've been lurking ever since the site was updated, but now I have got to come back and comment.  Mainly, I need to throw out a huge "Thank You" to Datsunfreak for all the work he's been doing on the van with me over the last several... well, forever.  There's a lot more to report, but I think I'll hold off on my passive/aggressive snark until I know he has pictures he's not posting... oops.  Sorry.  Once a passive/aggressive asshole, always a passive/aggressive asshole, I guess.
  • Haha 1
  • 2 months later...
