'62 Falcon Econoline
  • Replies 626
So far it has been an easy install.
Very easy.  :thumbup:
We'll see what a PITA the master cylinder will be in a couple weeks.
This looks like a bitch. Hoping it's not...   ^_^
Basically there's a big complex bracket under the floor that the pedal attaches to on one end, and the master cylinder attaches to on the other end. And we have to replace that bracket.
So I noticed that John didn't post pictures of the chrome center caps installed.  I'm glad because the four crusty lug nuts and one bare stud per wheel look like ass.  So I went online the other night to look for some new lug nuts.  I bought a set... along with a backup camera & monitor, stereo, four speakers (two 6.5" round 3-way and two 6x9 3-way), and an amp.  If I wasn't scheduled to work tomorrow, I might have sprung for expedited shipping, but since I knew I wasn't going to the shop this weekend, I can wait until Tuesday.
Oh man, I can't wait until Tuesday!
Tim decided on some snazzy purple lug nuts...
16997718_1267233316689123_87536503382094
Did some more grokking of the brake system and decided we'll save that for another day...   :rofl:
Tim was asking me about what mirrors might look cool, and I really dig the old school VW van mirrors, so we got some of those...
Tim was a little nervous about taking a hammer to a freshly painted van...
16939158_1267233303355791_84787398469723
That done we got to drilling...
Due to the way the mirror wants to mount, we elected to drill a hole straight through the door (both sides). Then we made a bigger hole on the inside to get a socket in there to tighten the nut on the back side of the mirror...
16865189_1267233323355789_19511532643036
Got the mirror base mounted...
17022443_1267233350022453_14438088887316
Rooted through my collection of rubber plugs and found two of these...
16938698_1267233373355784_33141216200220
Popped in the hole we drilled on the inside...
17155691_1267233386689116_28191798584417
Mirror stem/head bolted on...
16939620_1267233403355781_84509019137532
And now the other side done as well...
16939122_1267233423355779_24489383522161
I dig them...   :thumbup:
  • Like 5
Ok, so the master cylinder wasn't as bad as we expected.  Oh, it was a pain in the ass, just not as big a PITA as we feared.  We got all the old stuff out and the new stuff ready to go back in, sort of.  We still need to finger out the remote reservoir and clearance the parking brake bracket for brake lines... oh, and buy brake lines.  But we're getting there.  I've also decided that the main porpoise of the van is to be a camper, sort of thing.  Of course, having the fuel tank filler just inside the door, venting to the sleeping area, was giving me pause.  So last week I bought a pair of remote filler neck thingies (which haven't arrived yet) to install in the sides of the van and two remote filler neck plate thingies (which have arrived) for the saddle tanks.  Now we're going to have to build a false floor so we can route the filler pipes from the walls to the tanks.  Right now, I'm thinking of installing some drawers under this floor for tools, a spare tire, a jack, a cooker, and other things what need storing.  We'll see if those grand plans ever come to fruition.
I feel like Tim mostly posts in this thread whenever I don't post Saturday's progress pics on Saturday...   :rofl:
New master and bracket versus original...
17201160_1274652985947156_17824666548602
Old pedal had to be pried out, and the shaft on it that rotates about the master was in rough shape. So we cut it off...    ^_^
17265041_1274652962613825_90824343340492
Got a bolt that was a super good fit...
17201362_1274652959280492_18092033459964
Tim welding it on...
17191464_1274653012613820_47285555076197
Gave it a test, seems to work way smoother than before...
17191494_1274653035947151_67766499855311
The new master bracket also has a zerk fitting in it so that once it's all in there we can shoot the pivot full of grease so it's butter smooth...
Then on to a fresh coat of paint..
17264855_1274653052613816_64609120889903
Should go back in next week...
  • Like 3
I post on here indepen... ok, that's almost exactly what's going on.
I was worried that what the Chinese call "Stainless Steel" might turn out to be cast zinc or something.  No... oh, no no no.  This stuff welded so wonderfully it HAD to be real, honest to goodness, stainless.  Unfortunately, they do say "Water" instead of "Fuel" so we're going to have to get crafty.
This disc brake conversion kit is cool, but it does seem to require a lot of modification to the factory parts to make it work. It's not recommended for the neophyte to attempt it...
Today's job was making the old e-brake handle play nice with the new bits. First a notch on the tip...
17352527_1280214975390957_55906860977653
Then a notch in the middle...
17352301_1280214978724290_49534432660562
17264786_1280214972057624_91314308785762
Now it at least fits over the new brake lines...
17342513_1280215035390951_62285244568955
That done, Tim hands me the e-brake and says "clean and paint monkey!". At this time, I notice the handle on it is not exactly stock. It appears as though some previous owner had broken off the stock plastic handle, then cut a piece of conduit pipe, bent it at a 90 degree angle, and welded it on. That would not do.
So then I has an awesome idea!   B)
I ask Tim to cut off that goofy mess and tap the shaft...
17352015_1280215072057614_89842708164106
Then I go into the parts stash and find an old Hurst T handle I've been saving forever, and we tap that for the bigger threads of the e-brake shaft...
17342770_1280215092057612_88154013580147
Excellent!  :thumbup:
17308902_1280215112057610_43104175591328
Then it was time for the monkey to clean and paint...
17353107_1280215295390925_58590872971435
While that was drying, we finally did the last assembly (I hope) of the bracket/pedal/master combo...
17308716_1280215278724260_21204616984573
There is one more mod before install, though. Looking through the instructions we realize we also need to cut a notch into the bracket on the frame that holds the master cylinder for clearance...   <_<
So here's hoping it all goes in for good next time we are there...    :thumbup:
Also decided to just go ahead and replace all of the steel brake lines in the van. It will be much simpler in the end than trying to make the stock lines work with all this stuff. Plus they are 55 years old, so...    :rofl:
  • Like 3
We were grokking the master cylinder and bits which came in the kit and discovered that they "left out" one fitting we'd need.  We looked up the part number (and by "we" I mean "John") and found it to be an O'Reilley part.  We fingered out the lengths of pipe we'd need and of what size... yeah, y'all might remember a post I made on my 1200 thread where I said 3/16 is NOT the same as 3/8.  I felt kind of stupid telling the parts guy I needed thus and such adapter and a bunch of lengths of 3/8" brake pipe, then going, "No no no, that's way too big!"  Once he set me straight, I bought lines and unions and the adapter they "left out" of the kit.  When I went back to the shop, I assembled all the lines to the master cylinder, all running straight and spidery of course, and dumped the brake light switch out if its box.  "Oh, lookie here!" I says to myself.  "Here is that adapter they 'left out' of the kit!"  Three whole dollars, right down the drain!  Psh!
There is a consistency to all your builds
That's all I'm going to say about that
So I was thinking about the remote reservoir for the brake master cylinder and saw a purple catch can from Sickspeed on the Amazons.  I ordered it of course.  Well, I get an e-mail today saying, "...the purple cans are not in stock, would I like a gold or Neo-Chrome one instead?"  I cyphered and figgered on it for a moment and decided to gopher a Neo-Chrome unit.  Meh, it's LIKE purple... sort of.  I'll hide it inside the doghouse and no one will ever kno... oh, wait.  Y'all know.  Dang it!
Our new reservoir (said repurposed catch can) came in so naturally we took it apart...
17634732_1293466490732472_59983463401492
Tim wanted to install an air vent so we drilled and tapped a hole in the side, and made a vent pipe from an old 1/2" bolt. First drill through the bolt...
17553397_1293466474065807_48451730071514
Then cut the head off the bolt, screw it into the can, and pop on a filter to keep people and motors and shit out of it...
17626527_1293466464065808_34863846538009
Also got some new pipe fitting for the "bottom" of it to neck the outlets down to 3/8". Got some 3/8" nipples for the master cylinder too so we can run hoses from here down to there. But more on that later...
Before we can install that, we need to get the master cylinder in the hole. Here's Tim cutting off the corner of the mounting bracket underneath...
17553391_1293466607399127_28989872586896
And the master cylinder/pedal assembly going in...
17634749_1293466694065785_30946458630649
Tim also installed some new brake lines but I was distracted by a dog with a puffy tail, so...
  • Like 3
