'62 Falcon Econoline
  • Replies 626
Purple hub spacer...
20621155_1420779881334465_85876212163774
Purple steering wheel...
20525822_1420779884667798_77172839137096
We needed access to some bits (see below) so we elected to ditch the mesh screen and get some black paint in these holes while we're at it...
20476077_1420779878001132_83304023829560
We wanted to remove the fresh air boxes for building a brace to go between them, and figured we might as well clean them up and paint them while we had them out...
20431548_1420779911334462_63371438375455
The plan from here...
20479609_1420779918001128_21854615483930
  • Like 3
Attaching speaker pods to the brace...
20638533_1424488304296956_16914311244269
Mounting speakers...
20604582_1424488297630290_13010182500551
Grills on...
20604733_1424488300963623_93184546181034
Air boxes and brace bolted back into the van...
20526319_1424488347630285_40905613895960
Time for turn signals. Previous owner painted them yellow when they resprayed the van, so we had to fix that...
20663929_1424488357630284_16144903177429
Some shiny silver...
20638170_1424488417630278_37453622291670
Tim got some new lenses and gaskets...
20622252_1424488367630283_32765478932906
Original lenses are chrome around the edges, and I like that look. I thought for a minute about painting the outsides edges silver, but then had an idea. These are clear. So why not just paint the inside silver?   ^_^
20638462_1424488404296946_34537499163092
Both done...
20638044_1424488427630277_60598483476332
New seals were kind of floppy so I glued them to the light bezel so they'd stay in place...
20622084_1424488440963609_74643899151697
And all installed with new bulbs...
20604572_1424488467630273_60576890494650
Tim made some cool rubber mounts for the amp (not visible in this pic, sorry) and mounted it to the passenger wheelhouse under the seat...
20621944_1424488484296938_83437872734208
Also got the area around the headlights painted back, but you'll have to wait until next week to see that...
  • Like 3
I just ordered the RCA cables to hook up the amp, a belt to make door-pulls, and some rubber bulb-seal door-edging to "seal" the gap in the doghouse top cover.  Of course, being the cheap-ass* that I am, I opted for "free 5-8 business day shipping" soooo... none of that will arrive before next weekend.
*Ok, so it's technically "broke-ass" but who's counting?
Looking at this picture, I just realized we fucked up.  All those wires should be behind the cross bar.  Wait, should I have sent that in a PM or e-mail?
OK, so I went to the shop after work this evening and had a look at the wiring-harness-is-on-the-wrong-side-of-the-crossbar situation.  The crossbar is almost straight above the hole in the floor where the wiring harness goes through to the engine bay.  I finger we'll attach the wiring to the bar and drop straight down.  It isn't how I wanted the wiring to run, but it is what it is.  Besides, there isn't any way to attach the harness to the front bulkhead, short of using sticky-back zip-tie clamps... which never stay stuck, so it would have been hanging out in space to some extent anyway.  I'm prepared to be OK with the setup. Once resigned to a "solution" for that problem, I ran a wire from the stereo head-unit hole (remote on, sort of thing), and the wires from the front speakers, to the amp... area.  I didn't terminate them at this time though.
After much cussing and fiddling. I was able to get the wiring for the LED halos pushed through the stock wiring grommet...
20841139_1431012456977874_73193771132701
Then cleaned the overspray off the headlight rings and got the headlights installed...
20770367_1431012460311207_13471400409161
After polishing the headlight doors for the third time, I said fuck it. Discussed it with Tim, decided to just go ahead paint them silver.   :rofl:
20727983_1431012466977873_29290575487727
Then grabbed the grill and installed it too...
20799036_1431012490311204_62475170595384.
It now has a complete face for the first time ever.  :thumbup:
While I was working on that (with help from Tim), he was busy wiring up the halos, rerouting some of the wiring, installing the turn signal switch and a few other things...
20729671_1431012500311203_15580428377601
Next week should be the final wire tuck for the dash. Couldn't do it today due to lack of RCA cables to go from the radio to the amp.
We didn't have any good arm rests for this, and new ones are a bit spendy (and poke you in the hip), So Tim got a bright idea...
20915498_1437080949704358_23231537453308
I like it. Might even do this to my 210...
20882631_1437080946371025_42064694074015
While I did that, Tim got cracking on the dash wire tuck. Came out pretty good, and he installed the radio too...
20914321_1437080956371024_20941754382211
Got some trim with a bulb seal for the doghouse lid...
20914479_1437080983037688_18506131444955
I think Tim has cooled on the idea of the split lid, though. He's been making noise about buying another one to replace it...
And we drilled a hole and popped in a grommet for the battery cable to go through the side of the doghouse...
20953193_1437080986371021_49459202611717
I wonder if I've got enough lead in my pencil to zook that lid back together...
We're planning on padding and covering it so...
Hmm...
I'm not sure if we've mentioned that I'm planning to make the back of this thing into a camper... I'm planning to make the back of this thing into a camper.  So last night when I got up for the fourth time to go pee, I thought, "It's really going to suck having to open the door and crawl out of the back of the van six times a night to pee while camping.  I ought to use that extra 10 gallon fuel tank for black water!"  Then I thought about hauling around 10 gallons of pee... I think I'll open the door and crawl out.
I found an interesting thing on the Amazons the other day.  It's a tent-like cabana-vestibule thingy.  I think we can adapt/modify/improve on this to make a... well, a cabana-vestibule thingy for the side door.  I figure if we can make it "seal out" the weather at least as good as a tent, we should be golden.
In other totally-non-passive-aggressive-posting news, we insulated and reinstalled the house of dogs today... and by "we," I mean John single-handedly insulated the thing.  Thank you sir.  I did zook the lid back together... ish, and did a smattering of re-wire work which was needed.
Birthday (well, the anniversary thereof, to be pedantic) number 52 looks like a doable goal!  Hmm, B-52?  I kinda like the sound of that.
Some cool stuff showed up, including some stickers (Tim's favorite local radio station in the 70s/80s) and some butyl tape...
21271252_1449491695129950_79725389343142
Best mod so far...   ^_^
21271191_1449491688463284_61682544170934
Drilled a few tiny but strategic holes in the doghouse, scrubbed up the inside, applied some spray adhesive to the doghouse and insulation, and put it in. The wholes were for some tiny bolts and nuts with some big washers to hold it in place in case the adhesive gives up later on...
21317499_1449491698463283_64820676411953
Tim then got some new hardware to install the doghouse in the van. We also scraped all the old sealer from the floor and doghouse, used the new roll of butyl tape to replace it with, then bolted it in...
21231734_1449491721796614_30173585727168
And you can also see why we installed the grommet for the battery cable now.  ^_^
As Tim said, he welded the lid back together since we are now planning to install the wall behind the doghouse instead of on top of it. We will cover that at a later date because we are planning to insulate it as well, and will likely be adding some foam to the lid and wrapping it in vinyl.  :thumbup:
Good idea on insulating the crap out of the dog house the best you can :thumbup:
Actually thinking about using two layers on the lid...   ^_^
Tim got his exhaust tip thingie installed today. Looks pretty cool too...
21371188_1455150561230730_65069152374269
And his downpipes and mufflers are on too. Now we just need to get the muffler shop to connect these to the rear tips with about 3 feet of pipe...
21558938_1455150597897393_32890518034380
Tim got some new welding rod but it's a bit dainty, so he got crafty...
Squeeze three pieces in the vice, connect the other end to a drill..
21370903_1455150564564063_90234847817899
Voila! Nice fat welding wire that melts easy and flows out nice...
21616484_1455150557897397_43322165502185
  • Like 5
One smart sumabech. Kind of guy you want with you when you break down in the middle of nowhere
A set of spring shackles and bushings for the front suspension are on the way.  We ought to be able to knock that out next Saturday.  I'm contemplating removing one leaf per side as well to drop the nose a bit.  I also bought a roll if carpet yesterday on a whim... because I'm dumb that way.  Oh, yeah.  It is totally purple carpet, thanks for asking.  And I have a drawing of how I want to build the "moving pedestal" of my convertible sofa/bed.  Looks like it's only going to weigh somewhere around 85 pounds... MUCH lighter than I was afeared it was going to weigh while drawing it!
  • Like 4
The more I looked at the thing on the Amazons, the less I liked it.  I decided that I'd rather make a couple "tent walls" to "seal" the van and have some privacy in the vestibule of the open doors.  One will be in the opening of the van and the other will be between the doors.  (On Saturday I'll hold a up a blanket and have Datsunfreak shoost some pictures of what I'm thinking.)  I thought I'd buy an old tent and cannibalize a couple walls with zippers to do this.  Then it hit me, I bet I could find DIY tent making materials here on these intergoogles.  I did find a site and "ordered" some material and zippers.  It wasn't until later that I realized the site is based in Florida.  Yeah, I might never get that order after all.  And yes, I acknowledge that I am a douche for being annoyed that they might inconvenience me because their livelihood is under water.  At least I'm not bitching about it in the inter... oh, wait.
