DatsunSwag22 Posted April 24, 2015 Report Share Posted April 24, 2015 i have a 71 510 Wagon wit IRS from a 2-4 Door 510. its Almost done just want to know what u guys Would Do? I don't want to cut into the Back of the wagon. N i would like Coilovers but not enough money (600$) for them. So what would u guys do. i was going to Try n make something to Run stock for now. but not sure how i would. Pictures will be posted ASAP. thanks . Quote Link to comment
DatsunSwag22 Posted April 24, 2015 Author Report Share Posted April 24, 2015 sorry for the small pictures. Quote Link to comment
ggzilla Posted April 24, 2015 Report Share Posted April 24, 2015 I would put some springs back there. 1 Quote Link to comment
DatsunSwag22 Posted April 24, 2015 Author Report Share Posted April 24, 2015 i know that .. but I'm trying to find out should i try n run stock Quote Link to comment
ggzilla Posted April 24, 2015 Report Share Posted April 24, 2015 Why wouldn't you? Even 510s with rear coilovers use the stock mounting locations. Quote Link to comment
banzai510(hainz) Posted April 24, 2015 Report Share Posted April 24, 2015 need to see more photos Quote Link to comment
datzenmike Posted April 24, 2015 Report Share Posted April 24, 2015 Here is some reading.... There are 510 IRS into 510 goon... http://Sealik http://community.ratsun.net/user/2344-sealik/ has an opinion on what they were in. http://community.ratsun.net/topic/57709-69-510-wagon-irs-rear-conversion-for-reals/ http://community.ratsun.net/topic/47413-510-goon-irs-swap-goin-lower/ 610 with S13 IRS... http://community.ratsun.net/topic/56138-73-610-wagon-fj20-swap-irs/ This was all found by typing IRS swap into wagon into the search engine. 2 Quote Link to comment
hosestop@msn.com Posted April 24, 2015 Report Share Posted April 24, 2015 Hey Troy are the spring perches in the upper part of body , under back seat ,(from donor car re-welded in wag.) if not we have to use coil over on shocks and will need a stout shock mount with cross bar and you will have to build in car near back seat area , I need to come and see this thing , and need to get drivable here soon just no time lately . Quote Link to comment
jrock4224 Posted April 24, 2015 Report Share Posted April 24, 2015 go look at y wagon thread ... im bagging mine but i am using the stock rear inner fenders in my wagon 1 Quote Link to comment
Three B's Racing Posted April 24, 2015 Report Share Posted April 24, 2015 Coil overs fersure!!! But I'd make sure that you're ride height doesn't create lots of half shaft angularity otherwise you'll then have vibration from the universals transmitting through the car. Try and get those half shafts as parallel to the ground as you can. 1 Quote Link to comment
jrock4224 Posted April 24, 2015 Report Share Posted April 24, 2015 http://community.ratsun.net/topic/39556-projekt1972-wagon/ start inthe back when i decided to ditch the links and solid axle and swap to a irs ....you wont be able to use the stock irs spring mounts onthe upper side with out major modification ... coilovers are a good option but require major work to get to work you can see the black outline where i cut into the frame to make room for the shock tower ... i didnt tak as much as shown cause i wont be going coilovers and instead will only use this for a shock and im gonna be running single bellow bags..... the guy who used the leaf spring was pretty cool ... i havent heard how it works now this much later coilovers will be hard to make factory looking on a wagon ... ..my route will ... but i have to build a inner structure as i removed alot of the unibody frame rail ... as well as the area where the control arm travels up into the car ... its not very roomy for what i have planned 1 Quote Link to comment
flatcat19 Posted April 24, 2015 Report Share Posted April 24, 2015 I don't get why the diff is mounted so low. Extreme axle angle. Quote Link to comment
jrock4224 Posted April 24, 2015 Report Share Posted April 24, 2015 i have mine as high in the car as possible with basically same as a sedan and prolly didn't even need this hole to be this big 1 Quote Link to comment
]2eDeYe Posted April 24, 2015 Report Share Posted April 24, 2015 Yeah you can get the front cross member right up to the floor. Good to see your swap is starting to come together Jrock. :cool: 1 Quote Link to comment
jrock4224 Posted April 24, 2015 Report Share Posted April 24, 2015 lol picks from months ago lol 1 Quote Link to comment
]2eDeYe Posted April 24, 2015 Report Share Posted April 24, 2015 Are they in the build thread? :lol: Quote Link to comment
jrock4224 Posted April 24, 2015 Report Share Posted April 24, 2015 i think so lol ,,, i figured u looked at my threads daily to police my schenangians 3 Quote Link to comment
datsunfreak Posted April 25, 2015 Report Share Posted April 25, 2015 i think so lol ,,, i figured u looked at my threads daily to police my schenangians Wait... Jrock has build threads?!? 2 Quote Link to comment
jrock4224 Posted April 25, 2015 Report Share Posted April 25, 2015 yeah they sit stagnant and i buy other things and start threads for that and they dont get work either ...got my fresh crf450r motor back last week with new cams valves and fresh sleeve and piston ... and havent even put that back together yet ... feeling overwhelmed Quote Link to comment
datsunfreak Posted April 25, 2015 Report Share Posted April 25, 2015 feeling overwhelmed Want me to come over and help out? ^_^ Quote Link to comment
flatcat19 Posted April 25, 2015 Report Share Posted April 25, 2015 Want me to come over and help out? ^_^ F jrock. I'm closer. Get yer ass over here. 2 Quote Link to comment
