HRH Posted January 24, 2016 Report Share Posted January 24, 2016 So today was a good day. I finally hit 6000 rpm in 5th gear. On my private test track, because you know the highway would be highly illegal. 6000 rpm in 5th gear, gentlemen, equates to 132 mph. In Ugly Betty. ;) That was with the NACA duct still covered over, lights on and fan at half speed. I figure if I have the NACA duct uncovered and switching to the larger throttle body, I can probably get Ugly Betty to 140 mph, if not 145. :D And yes, that is by the numbers speed, not speedometer. Found a nice gear calculation site that takes into account transmission ratios, final drive ratios, and tire size. 3 Link to comment
hobospyder Posted January 24, 2016 Report Share Posted January 24, 2016 Datsun makes a damn fine heater. It's heavy, but it's got wheels so... abut the size of a compact pickup, kinda warms a 1900sqft pole building. Add in being high from exhaust fumes and moving around and it works great. Also doubles as a hand warmer Link to comment
q-tip Posted January 24, 2016 Report Share Posted January 24, 2016 I'm guessing it was closer to actual speed of 120. There is a weird aerodynamic wall at 130 that requires a lot more power to go faster, like 10hp for 5mph. I hit 120 in my KA 510 and it was really struggling. I've done 140 in a '29 model a, but that had over 500hp and weighed 1700lbs, and only 4k in too gear. Been riding shotgun in a 911 turbo at 165 and it didn't seem to be trying all that hard. Link to comment
fritzdixxon Posted January 24, 2016 Report Share Posted January 24, 2016 Are you saying ugly Betty isint aerodynamic? My 82 Ford Fairmont (first car given to me by my uncle, with a blown trans that I had to pull and get rebuilt), I could hit 240 km/h 150ish mi. And it was as boxy as betty 1 Link to comment
HRH Posted January 24, 2016 Report Share Posted January 24, 2016 Yeah, the aerodynamics of the 510 are actually much worse than the Maxima. The windshield rake is farther back for one. Plus Ugly Betty is lowered quite far. And which KA? E or DE? And was there any work done to it? I'm figuring the Maxima 2.4 is probably around 150 hp now given the cam and other tweaks. Car weighs 2500 at current, can get a bit lighter with a few other parts removals. 1 Link to comment
hobospyder Posted January 24, 2016 Report Share Posted January 24, 2016 and maybe drop a load in a toilet before hopping in 1 Link to comment
fritzdixxon Posted January 24, 2016 Report Share Posted January 24, 2016 and maybe drop a load in a toilet before hopping inLes weight at least another. 5 mph 1 Link to comment
tr8er Posted January 24, 2016 Report Share Posted January 24, 2016 Dope!!! I've surely gone faster, but not in a Maxima/510. That must feel good. You should dyno. 2 Link to comment
HRH Posted January 24, 2016 Report Share Posted January 24, 2016 You know, she's just the play toy now, but I may eventually dyno her. I'm more interested in going faster with the turbo motor in the new Z race car. :) But it still would be nice to know. Link to comment
Fat510 Posted January 24, 2016 Report Share Posted January 24, 2016 So today was a good day. I finally hit 6000 rpm in 5th gear. On my private test track, because you know the highway would be highly illegal. 6000 rpm in 5th gear, gentlemen, equates to 132 mph. In Ugly Betty. ;) That was with the NACA duct still covered over, lights on and fan at half speed. I figure if I have the NACA duct uncovered and switching to the larger throttle body, I can probably get Ugly Betty to 140 mph, if not 145. :D And yes, that is by the numbers speed, not speedometer. Found a nice gear calculation site that takes into account transmission ratios, final drive ratios, and tire size. Get a GPS app or navigation unit that shows speed, its prolly the most accurate you can get Link to comment
fritzdixxon Posted January 24, 2016 Report Share Posted January 24, 2016 ^^^ yup, some even keep track of stats Edit, there are just speedometer aps out there also. Link to comment
q-tip Posted January 24, 2016 Report Share Posted January 24, 2016 Yeah, the aerodynamics of the 510 are actually much worse than the Maxima. The windshield rake is farther back for one. Plus Ugly Betty is lowered quite far. And which KA? E or DE? And was there any work done to it? I'm figuring the Maxima 2.4 is probably around 150 hp now given the cam and other tweaks. Car weighs 2500 at current, can get a bit lighter with a few other parts removals. DE, full length header most emissions equipment removed, I think it has some kind of chip because the limmiter is at 7250, 3.90 rear gear. I know the maxima has better aerodynamics but not that much better, its still a brick. I haven't done a run for speed since I put the splitter on, I know it made it cut the wind a lot better, at 70mph it runs about 200rpm less than it used to, I'm just worried about tearing the fiberglass off at high speed. Link to comment
hobospyder Posted January 24, 2016 Report Share Posted January 24, 2016 DE, full length header most emissions equipment removed, I think it has some kind of chip because the limmiter is at 7250, 3.90 rear gear. I know the maxima has better aerodynamics but not that much better, its still a brick. I haven't done a run for speed since I put the splitter on, I know it made it cut the wind a lot better, at 70mph it runs about 200rpm less than it used to, I'm just worried about tearing the fiberglass off at high speed. fiberglass? i'd be worried your fender would fly off or is that what you're talking about? Link to comment
HRH Posted January 24, 2016 Report Share Posted January 24, 2016 Does the splitter have supports? If not, I'd probably add some, and sturdy. There's a lot of wind at 140. Link to comment
q-tip Posted January 24, 2016 Report Share Posted January 24, 2016 It doesn't have any support but its pretty stiff, and a big dent from a rock on my way to camby last year. My plan was to tie it into the under side of the apron and maybe all the way to the front crossmember, mayby even from the upper part of the balance to the top of the splitter. Link to comment
q-tip Posted January 24, 2016 Report Share Posted January 24, 2016 fiberglass? i'd be worried your fender would fly off or is that what you're talking about? Those are tac welded on, they aren't going anywhere......unless the rust gives way... Link to comment
HRH Posted January 24, 2016 Report Share Posted January 24, 2016 This guy's a little goofy from his previous videos, but at least he's not being a giant pussy with "Snowmaggedon." :D 3 Link to comment
r0p0doe Posted January 24, 2016 Report Share Posted January 24, 2016 This guy's a little goofy from his previous videos, but at least he's not being a giant pussy with "Snowmaggedon." :D Fuck,you beat me to it lol :rofl: 1 Link to comment
datzenmike Posted January 24, 2016 Report Share Posted January 24, 2016 Les weight at least another. 5 mph Weight would impact climbing a hill where the engine has to lift more weight but otherwise the friction on the bearings would remain constant. For high speed there is rolling resistance.... tires soft (high) or firm (low) and some bearing friction but these stay about the same. Much, much more is the air resistance. The less aerodynamic, the more the air is disturbed and caught and dragged along with you. You are trading your vehicle power for moving air out of the way. If your car is very aerodynamic it moves very little air out of the way and then allows it to seamlessly move back to where it was. Compare this to a tractor trailer that passes you on the side of the road. Imagine all that buffeting and blasts of air as being paid for by engine power and it is. The air didn't magically move. Disturbing the air eats power in VAST amounts. If you have 50 hp and your top speed is 80 MPH, it will take 200 hp to double your speed to 160MPH. Four times the power to only double your speed. This means that going from 130 to 140 will take a huge increase in power and why land speed records are so hard to break. You can reduce drag or increase power. In some classes you are stuck with limitations on vehicle modification (drag) so you need to find more HP. Link to comment
Laecaon Posted January 24, 2016 Report Share Posted January 24, 2016 This guy's a little goofy from his previous videos, but at least he's not being a giant pussy with "Snowmaggedon." :D Ive done car skiing before. Used my Ford Thunderturd, and some goodwill skis. Cops didnt care. Link to comment
fritzdixxon Posted January 24, 2016 Report Share Posted January 24, 2016 Gt wars were the best. 2-3 gts all tied with same length rope and we would demo derby until only one rider remained. One neighborhood here has ditches instead of sidewalks, going wide on corners and into the ditches and ramping the approach for drivways was great until Brad hit a culvert. Link to comment
VFR800 Posted January 24, 2016 Report Share Posted January 24, 2016 Was @ Lake Somerset on sunday and saw some water based skiing going on. 2 Link to comment
q-tip Posted January 24, 2016 Report Share Posted January 24, 2016 Is every pickup equipped with a flat bed down there? 2 Link to comment
VFR800 Posted January 24, 2016 Report Share Posted January 24, 2016 Is every pickup equipped with a flat bed down there? No,plenty of stylesides too. Link to comment
q-tip Posted January 24, 2016 Report Share Posted January 24, 2016 Too bad, you Aussies make a really useful flatbed. 2 Link to comment
