BarryA Posted September 29, 2008 Report Share Posted September 29, 2008 Starting to build a custom dash panel, and will need to match an aftermarket gauge to the stock in-tank fuel level sender. VDO and other gauge companies usually have more than one ohm range gauge available, but often don't specify which gauge works with which manufacturer's senders - if the gauge and sender don't match, the gauge won't read the tank level accurately. Quote Link to comment
Drummerboy4as Posted April 19, 2009 Report Share Posted April 19, 2009 You ever get an answer for this? Quote Link to comment
ggzilla Posted April 19, 2009 Report Share Posted April 19, 2009 35 ohms half full (per Nissan Factory Service Manual) We measured some various Datsun senders and came up with this: * 12 ohms fully up * 88 ohms fully down Quote Link to comment
Guest DatsuNoob Posted April 20, 2009 Report Share Posted April 20, 2009 Couldnt a guy just use any, so long as the sender in the tank or fuel cell matches the ohm reading on the fuel gage. For example, chev sender and chev autometer gage? Why not just swap a sender and buy the matching gage? It doent have to be nissan, just has to be semi accurate. Quote Link to comment
