*fart* Posted July 16, 2016 Author Report Share Posted July 16, 2016 Thanks for the constructive criticisms lol! I think you guys misunderstood. The truck is done. We just run open cylinders for better exhaust flow, and switched the clutch pedal to be the gas pedal. Lol. Thanks for the helpful comments tho... Want to build this truck to be a reliable daily that rips. Im gonna be running a mild street cam so heat will always be an issue. Travis at rhode alliance customs is hooking me up with a set of custom headers, and is a master with sheet metal, so the tunnel will be a breeze. Will prob either coat the pipes or give them a good wrap. Once i get the truck on the road I might make some air dams to cool the wilwood big brake kit and get some air around the tranny. Still need to figure out what kind of radiator and fan setup will cool this motor down. Stay tuned.. will have some serious updates soon.. 3 Quote Link to comment
Charlie69 Posted July 17, 2016 Report Share Posted July 17, 2016 If it is done we need more pictures Please! Quote Link to comment
Stoffregen Motorsports Posted July 17, 2016 Report Share Posted July 17, 2016 I think the done comment was a joke, hence the LOL. But yeah, I'm confused now. There's a lot to think about when cutting into a firewall like that. If you push the motor too far back, there's not going to be room for a heater and in some extreme cases, fitting the stock dash is impossible. I built a '53 GMC a couple years ago with a 24V Cummins in it and the valve cover could have been a good place to mount a cup holder, that's how far back it went. 3 Quote Link to comment
2wheel-lee Posted July 18, 2016 Report Share Posted July 18, 2016 /\ A Cummins in a '54 GMC is rad...love it! 2 Quote Link to comment
*fart* Posted August 5, 2016 Author Report Share Posted August 5, 2016 Got some more progress done on the truck. Travis at Rhode Alliance Customs is almost done with the hard stuff! Motor is all mounted, tranny is mounted. Travis made up a custom set of front facing headers. He is about to pull the body off for the last time and get the new floor pans and tranny tunnel welded in. 3 Quote Link to comment
Stoffregen Motorsports Posted August 5, 2016 Report Share Posted August 5, 2016 Finally a guy who looks like he knows what he's doing. With this level of involvement, I have confidence that this truck will actually get finished. I think a lot of members here on Ratsun get weird about people cutting into vintage Datsuns, because the majority of them will probably never run again. 1 Quote Link to comment
*fart* Posted August 5, 2016 Author Report Share Posted August 5, 2016 This truck was my baby... When it got stolen i was ready to kill someone... haha... This thing will be back on the road for sure!! Goal is by the end of the summer! 1 Quote Link to comment
bilzbobaggins Posted August 5, 2016 Report Share Posted August 5, 2016 Nice. Floor pans look amazing 1 Quote Link to comment
distributorguy Posted August 8, 2016 Report Share Posted August 8, 2016 Looks like you have to pull the motor to get the distributor out, or even change the cap. 1 Quote Link to comment
*fart* Posted August 8, 2016 Author Report Share Posted August 8, 2016 I got a plan for the distributor. Thinking about making a little removable plate that bolts to the under structure of the cowl. That way Ill just have to remove the cowl beauty cover... remove plate and access distributor. There is already space for a pocket to access plug wires and adjust distributor... and making a removable cover to remove distributor seems like a pretty good access solution. Quote Link to comment
*fart* Posted September 7, 2016 Author Report Share Posted September 7, 2016 So I got the truck back from Rhode Alliance Customs! Travis did a ton of work on this thing! Tons more to go tho! I started ordering some things that ill need to get it fired up. Got the air cleaner installed today! Time to cut a hole in the hood! 2 Quote Link to comment
racerx Posted September 7, 2016 Report Share Posted September 7, 2016 Would a shaker hood work 1 Quote Link to comment
*fart* Posted September 7, 2016 Author Report Share Posted September 7, 2016 The motor wont move too much. I cut the hood this afternoon. I still have to open it up a little more for clearance. Then I am going to rivet some snaps to the hood and make a little leather cover to go over part of the air cleaner. Then when it rains and in not driving it ill snap another cover to keep some of the water out the engine... Now i have to cut the hood in front of the scoop and bend it down so that the scoop isnt picking up any hot air from the engine... 2 Quote Link to comment
*fart* Posted September 7, 2016 Author Report Share Posted September 7, 2016 Thanks man... Just a test fit really ... Think I'm gonna end up needing a new hood... 1 Quote Link to comment
racerx Posted September 7, 2016 Report Share Posted September 7, 2016 Paint the hood flat or gun metal black 1 Quote Link to comment
paradime Posted September 8, 2016 Report Share Posted September 8, 2016 I love progress!!! The scoop sticking up from under the hood is evil. Nice work on your baby. 1 Quote Link to comment
distributorguy Posted September 8, 2016 Report Share Posted September 8, 2016 I'll warn you the new replacement hoods fit terrible, and the stampings are poor at best. Mine came with a major warp on both sides, causing what's essentially a 10" wide dent on either rear corner. You'd be best off fixing yours. 1 Quote Link to comment
*fart* Posted September 8, 2016 Author Report Share Posted September 8, 2016 thanks for the heads up... I wont count mine out yet... have to keep my eyes peeled for one in a junkyard... 1 Quote Link to comment
DISLEXICDIME Posted September 10, 2016 Report Share Posted September 10, 2016 Get another hood skin it and make a hump 1 Quote Link to comment
*fart* Posted September 23, 2016 Author Report Share Posted September 23, 2016 Got a little bit of work done on the hood so that the scoop can grab all clean air... more to come! 3 Quote Link to comment
distributorguy Posted September 23, 2016 Report Share Posted September 23, 2016 It would have been more efficient if you installed it backward... Ram air is no good until you exceed 110 mph. Not very useful in this application. B) 2 Quote Link to comment
*fart* Posted September 24, 2016 Author Report Share Posted September 24, 2016 this isn't exactly a race car... Haha. When I need more air tho I'll think about that... 1 Quote Link to comment
mcordero8 Posted September 24, 2016 Report Share Posted September 24, 2016 It Looks clean. 1 Quote Link to comment
*fart* Posted September 27, 2016 Author Report Share Posted September 27, 2016 Got a little bit more work done on the hood... But thats probably the least of my worries at this point... Got a water pump and radiator the other day... Still a bunch of work to do to fit the radiator and such.... Need to adjust the angle that the collector comes of the front facing headers and weld it back up. I also got some mufflers in the mail... 3" Diameter and 9" long LOL... They are a straight through muffler from Dynomax... Hopefully they will make it not sound like a demo derby car! haha... I have the fuel system figured out, I just need to get a new fuel pump. 3 Quote Link to comment
