hobospyder Posted July 10, 2015 Report Share Posted July 10, 2015 can see what i'm talking about when i say i looped it with this picture Quote Link to comment
njoz1200ute Posted July 10, 2015 Author Report Share Posted July 10, 2015 Steering Column bushing part# 48910-H1021, don't know if Nissan still sells these. MADDAT also sells this part. I did see that Maddat sells them. Why has no one 3D printed one yet or made an equivalent out of rubber? Ever 1200 I have owned (2 now) have had perished steering bushings Quote Link to comment
njoz1200ute Posted July 10, 2015 Author Report Share Posted July 10, 2015 Could always shorten the metal fuel line? Done that a few times too... working just fine how she sits and i'd have to get a flare tool, why fix what ain't broke? Both good ideas. I'll flip a coin and go with either. Quote Link to comment
njoz1200ute Posted July 10, 2015 Author Report Share Posted July 10, 2015 You just unscrew the pipe from the right side of the carb, unscrew the cap from the left side, and swap them out. ;) It'll feed perfectly fine from either side. :thumbup: I actually did not know this :angel: Quote Link to comment
njoz1200ute Posted July 18, 2015 Author Report Share Posted July 18, 2015 How do I get my build page transferred to "Project Datto" section? Quote Link to comment
datsunfreak Posted July 18, 2015 Report Share Posted July 18, 2015 How do I get my build page transferred to "Project Datto" section? Ask datzenmike to do it for you. Quote Link to comment
datsunfreak Posted July 18, 2015 Report Share Posted July 18, 2015 And apparently he did. :rofl: Quote Link to comment
njoz1200ute Posted July 21, 2015 Author Report Share Posted July 21, 2015 Got some new parts in the mail. Cigarette lighter assembly reproduction part from Thailand. Also 2 x chrome plated knobs from California. I have never seen these types of knobs before. It seems like the 1200 ones are always black. I can only hope that I can also find some heater knobs to match? Had a problem with the Cigarette lighter assembly. It seems like the brass screw in backing plate is waaaaaaaaaay too long. I cannot get it screwed onto the dash. Do you guys reckon I trim a section of it off to get it to fit or am I doing something wrong?ComparoNew knobs Quote Link to comment
njoz1200ute Posted July 21, 2015 Author Report Share Posted July 21, 2015 Also...thanks datzenmike Quote Link to comment
njoz1200ute Posted July 24, 2015 Author Report Share Posted July 24, 2015 Also noticed how short the backing plate is on this Tech Wiki photo...compared to mine which is much longer.Pain in the rear, I guess I have to trim it down. Quote Link to comment
njoz1200ute Posted July 24, 2015 Author Report Share Posted July 24, 2015 can see what i'm talking about when i say i looped it with this picture I just noticed your electric choke. Where does it connect to? I was told to connect mine to the neg (-) side of the coil? Is that not correct? Quote Link to comment
datsunfreak Posted July 24, 2015 Report Share Posted July 24, 2015 I just noticed your electric choke. Where does it connect to? I was told to connect mine to the neg (-) side of the coil? Is that not correct? Normally it would go to the positive side of the coil. Nothing should be connected to the negative side except the distributor. Quote Link to comment
hobospyder Posted July 24, 2015 Report Share Posted July 24, 2015 i ended up hooking it up to the original wire for the choke. i think it's a blue one but i can't remember off hand. stock choke was electric Quote Link to comment
njoz1200ute Posted July 24, 2015 Author Report Share Posted July 24, 2015 Normally it would go to the positive side of the coil. Nothing should be connected to the negative side except the distributor. Thanks for the correction :w00t: i ended up hooking it up to the original wire for the choke. i think it's a blue one but i can't remember off hand. stock choke was electric I don't believe the aussie 1200 wiring loom has a stock wire for a choke unless I am wrong. Quote Link to comment
datsunfreak Posted July 24, 2015 Report Share Posted July 24, 2015 I don't believe the aussie 1200 wiring loom has a stock wire for a choke unless I am wrong. Depends on age. Seems like most Datsuns had an electric choke past '71ish? I don't think USDM 1200s did, but if your ute (or harness) is from a newer than '73 model, I'd bet it would... Quote Link to comment
hobospyder Posted July 24, 2015 Report Share Posted July 24, 2015 i was just using my truck as an example of what could be done for the fuel line and why i did it the way i did it. i don't know anything about the 1200 wiring loom was just giving ideas as long as it's an always on stream of power i think you'll be good Quote Link to comment
njoz1200ute Posted July 24, 2015 Author Report Share Posted July 24, 2015 From tech wiki: The electric choke on the 1200 (1972 and up have electric choke) has power supplied from the ignition switch circuit. However, this is switch on/off by the choke relay from a signal put out by the alternator/regulator "N" wire. This means the choke only gets power when the ignition is ON and the alternator is putting out power (engine running). Other makers use an oil pressure switch for the same purpose. For a 1971 car, you could simply hook it up directly, the downside would be if you let the car sit with IGN on for a while before starting the choke would open up, even if it is cold outside, possibly preventing the engine from starting. Sounds like if I can't find a choke wire in my harness i can tap into the + side coil but I have to be careful not to leave the key on Acc Quote Link to comment
datsunfreak Posted July 24, 2015 Report Share Posted July 24, 2015 Sounds like if I can't find a choke wire in my harness i can tap into the + side coil but I have to be careful not to leave the key on Acc The coil wire is not hot on the "accessory" position, Just when it's in the "on" position. ;) Quote Link to comment
njoz1200ute Posted September 15, 2015 Author Report Share Posted September 15, 2015 N00b question. I bought a Centric brand master cylinder from RockAuto. 1. Do the internals need to be greased before use? 2. Does it matter its for LHD even though my ute is RHD? No instructions were provided. Already bolted it up too Quote Link to comment
datsunfreak Posted September 15, 2015 Report Share Posted September 15, 2015 1. Do the internals need to be greased before use? It couldn't hurt to take it apart and make sure the inside is clean. Chinese factories aren't super good at this. You have a 95% chance that it's okay as is. 2. Does it matter its for LHD even though my ute is RHD? There is no difference. Same exact part for both. Quote Link to comment
njoz1200ute Posted September 28, 2015 Author Report Share Posted September 28, 2015 Need some advice. I may have the opportunity to purchase a turbo A12 engine from a speed shop in Australia and bring it over to install in my ute project. Or the entire ute possibly too. My question would be, how difficult is it to swap a turbo A series into a non-turbo A series body? Is it a matter of swapping the engine & transmission and the wiring harness and bob's your uncle?Or does it require a lot of work? Keep in mind as you can probably tell I am just a DIY hobby mechanic, not fully trained. I have done a A12 to A14 swap and vice versa and have been pretty successful doing that, but never have touched a turbocharged engine setup. Pic of car:Thanks. Quote Link to comment
datsunfreak Posted September 29, 2015 Report Share Posted September 29, 2015 My question would be, how difficult is it to swap a turbo A series into a non-turbo A series body? They are all non-turbo originally. ;) So yes, just a matter of pulling all the gear from one truck and installing in the other. And I'd swap over anything that looks even remotely usable. Quote Link to comment
njoz1200ute Posted September 29, 2015 Author Report Share Posted September 29, 2015 Turbo A12 or twin carbed gx head A14.......tis the question. Quote Link to comment
datsunfreak Posted September 30, 2015 Report Share Posted September 30, 2015 Turbo A12 or twin carbed gx head A14.......tis the question. Here's the answer. Do you want to drive the car, or just work on it? B) Quote Link to comment
njoz1200ute Posted September 30, 2015 Author Report Share Posted September 30, 2015 Daily drive is the goal, except for winter What are you inferring? Quote Link to comment
