njoz1200ute Posted September 24, 2017 Author Report Share Posted September 24, 2017 From tech wiki. Looks like mine but doesn't identify source. A sleeker version can also be fabricated: * The rubber insulator picture is a stock 60-series rubber unit. Quote Link to comment
datsunfreak Posted September 25, 2017 Report Share Posted September 25, 2017 On a side note, I am using BMW mounts which are much taller and might eliminate the need for the spacers you used. Worth a shot? 1 Quote Link to comment
njoz1200ute Posted January 3, 2018 Author Report Share Posted January 3, 2018 Build update. Since the beautiful tranny mount install i haven't done too much to the uterus project. Took me awhile to figure out how to wire the fuel tank sender since the factory harness is gone. But everyone said stuff a crimped connector in there so i did. I was able to buy a battery and test my remote wiring system. Works great! I was even able to turn over the A14. Test lights and other stuff. Other than no lights for ignition,charge,brake,high beam on the cluster all seems good. Had to replace a faulty starter motor. Only 2 bolts but its a pain in the ass trying to get clearance to those bolts. Especially with only a small budget tool set consistenting of hand me downs that i own. I finished or mostly finished the headlining. I am very happy with it and thank you to the hundreds of companies I emailed for free stickers. VP race fuels your stickers are awesome! And Whiteline sent me an entire car decal set for a full on race car! I was blown away. I have developed a sticker fetish now. I was a good boy this year and Santa got me new seats to replace my Coupe seats which are mint 70s but just don't give enough cabin room. I was surprised how different B110 seats are from B120 seats. And good B120 seats are no where to be found in the northern hemisphere....so.... 2 Quote Link to comment
njoz1200ute Posted January 16, 2018 Author Report Share Posted January 16, 2018 So my immaculate B110 seats don't fit to my liking. They are much different than B120 seats. Fast forward to Xmas. Santa delivered me new eBay cheapies. I was a little disappointed in the fact that the mounting points on the bottom of the seats were completely covered in the seat material. I had to cut away material to access the mounting threads. For reference the seat mounting points on these eBay cheapies are 10 1/16th" wide X 12 1/8" long. Pretty different than the factory mounting points so not much opportunity to use the stock rails. The universal sliding rails that came with these seats also came with different seats I put on the coupe before i sold it. I didn't use them then because the sliding mechanism is crap. So more custom mounts to be had! Bottom of seat. After thinking up elaborate ways to use the stock rails or weld or fabricate i decided to KEEP IT SIMPLE STUPID. I decided to take one 1.25" and one 1.75" section of mild steel angle and simply drill and bolt them to the factory holes as a base for the new seats. Rails with measurements Measure once drill twice. Rear rail had to be trimmed at 45 deg angle to fit next to the tunnel. Drilled Alt view Front rail Trial fit of the seats told me I needed to prop the back of the seat up and give them a tilt forward. One, to avoid headrests hitting back glass and two, to make seat not as slouched with the seat belt hitting passengers face. I bought 1/2" spacers made of nylon but was not enough so I had to raise the whole back rail section another 3/8 or so. So it kind of "floats" above the factory rear mounts I am not terribly happy with that. I feel the weight is more direct on the bolts so I may lower it back down and get spacers milled or try find online....suggestions? Here is one seat installed. Legroom slightly diminished from stock but seat is lower which is good. Also need a way to lower seat belt height...suggestions? Rails First seat installed 2 Quote Link to comment
njoz1200ute Posted January 16, 2018 Author Report Share Posted January 16, 2018 Thinking of dropping the rear angle so it sits on the rear risers. Bought a 1.25" square tube today. Amd 60mm M8 bolts. Thinking of using a full length tube as a spacer ON TOP of the angle then thru bolting the angle and tube to the seats. Not sure how to attach the tube if at all to the angle. Front not sure about how to improve. Quote Link to comment
datsunfreak Posted January 18, 2018 Report Share Posted January 18, 2018 Not sure how to attach the tube if at all to the angle. 2 Quote Link to comment
njoz1200ute Posted January 18, 2018 Author Report Share Posted January 18, 2018 Lol Quote Link to comment
njoz1200ute Posted March 18, 2018 Author Report Share Posted March 18, 2018 These seats are a pain in my ass. Figuratively and literally Quote Link to comment
datsunfreak Posted March 18, 2018 Report Share Posted March 18, 2018 These seats are a pain in my ass. Figuratively and literally Yeah, steel frame seats can be that way. Composite seats are a lot more comfortable... Quote Link to comment
Dguy210 Posted March 19, 2018 Report Share Posted March 19, 2018 These seats are a pain in my ass. Figuratively and literally Porsche tombstone seats fit well, look period correct (if in black), and are very comfortable. Pretty common seat. Just a thought. Quote Link to comment
datsunfreak Posted March 19, 2018 Report Share Posted March 19, 2018 Porsche tombstone seats fit well, look period correct (if in black), and are very comfortable. Pretty common seat. Just a thought. Yes, but the seat backs are too thick. That's what got him into this mess... :rofl: Quote Link to comment
Dguy210 Posted March 19, 2018 Report Share Posted March 19, 2018 Yes, but the seat backs are too thick. That's what got him into this mess... :rofl: Lol, I must have missed that. Ute problems I guess :rofl: Quote Link to comment
datsunfreak Posted March 19, 2018 Report Share Posted March 19, 2018 Ute problems I guess The struggle is real, yo... 1 Quote Link to comment
njoz1200ute Posted April 19, 2018 Author Report Share Posted April 19, 2018 New wheels. Long story but I bought a NOS pair of Rotas and tried to match them with new ones. Unfortunately the color is off a little. Enough to bother my OCD brain. I might get them hydrodipped with a sticker graphic. 1 Quote Link to comment
Lockleaf Posted April 20, 2018 Report Share Posted April 20, 2018 Put matching ones on each side. Then you won't ever see the mismatch. 1 Quote Link to comment
njoz1200ute Posted April 20, 2018 Author Report Share Posted April 20, 2018 Staggered set 15x8 one color. 15x9 other Quote Link to comment
njoz1200ute Posted May 6, 2018 Author Report Share Posted May 6, 2018 Plastidip to another color maybe? I love the bronze though. Quote Link to comment
njoz1200ute Posted May 6, 2018 Author Report Share Posted May 6, 2018 Installed my custom radiator piping today. I would have preferred blue to match some of the other accent but yellow is not too bad. I also found a New Old Stock oil cap to replace the 38 year old original one And I also found some new Chrome Fender mirrors also New Old Stock. I've spoken to a few Nissan dealers in the USA trying to find original brake line so that I don't have to fabricate new ones but it looks like they are all gone 1 Quote Link to comment
datsunfreak Posted May 7, 2018 Report Share Posted May 7, 2018 I've spoken to a few Nissan dealers in the USA trying to find original brake line so that I don't have to fabricate new ones but it looks like they are all gone If you go to any chain parts store they will have pre-made straight lines you just need to bend to the right shape? They aren't hard to bend. 1 Quote Link to comment
KELMO Posted May 7, 2018 Report Share Posted May 7, 2018 ^^^^This....I did for the clutch hard line on both coupes......3rd time was a charm. :thumbup: 1 Quote Link to comment
njoz1200ute Posted August 9, 2018 Author Report Share Posted August 9, 2018 The moment you realize...... you used US thread brake fittings for every single brake line, when the tech wiki says M10 metric fittings. ??? Quote Link to comment
njoz1200ute Posted November 17, 2018 Author Report Share Posted November 17, 2018 The rota wheels ended up being too wide in the back. Not sure i will end of using them. This body is way too nice to cut up for fender flares. In other news, the A14 engine is gone. This build will now be A12gx turbo EFI. Stay tuned. No pun intended Quote Link to comment
njoz1200ute Posted November 17, 2018 Author Report Share Posted November 17, 2018 On 3/18/2018 at 8:20 PM, Dguy210 said: Porsche tombstone seats fit well, look period correct (if in black), and are very comfortable. Pretty common seat. Just a thought. Porsche 914 seats fit well. I had a set for a few weeks but traded them. Quote Link to comment
njoz1200ute Posted November 18, 2018 Author Report Share Posted November 18, 2018 Got the A12 on a stand ready to strip down for cleaning and paint Quote Link to comment
njoz1200ute Posted April 21, 2019 Author Report Share Posted April 21, 2019 This builds getting off the heasy. Updates soon. 1 Quote Link to comment
