datsunfreak Posted May 2, 2017 Report Share Posted May 2, 2017 New calipers arrived in the mail Did I order the wrong ones? Maybe? What are they for? And did we ever determine if the truck even has 1200 struts? Quote Link to comment
njoz1200ute Posted May 2, 2017 Author Report Share Posted May 2, 2017 It's a good question I was told by people on the other Forum that the struts or not 1200 but the struts are a from a 120y Maybe there is two different versions of a 120y strut and brake caliper? Is there two different versions with the us version of the B210? Quote Link to comment
datsunfreak Posted May 2, 2017 Report Share Posted May 2, 2017 It's a good question I was told by people on the other Forum that the struts or not 1200 but the struts are a from a 120y Maybe there is two different versions of a 120y strut and brake caliper? Is there two different versions with the us version of the B210? USDM B210 uses different bits than other markets. Here the B210 basically used all 510 stuff, equivalent to a Sunny Excellent overseas. So we got the Sunny Excellent suspension and brakes, but none of the other cool bits... :crying: Quote Link to comment
njoz1200ute Posted May 2, 2017 Author Report Share Posted May 2, 2017 In that era, 1200s and 120Ys would use the same struts/brakes. USDM "120Y"s used bigger struts/brakes, but not in other markets. Get some B310 control arms, steering knuckles, outer tie rods, and t/c rods. Put those on, then swap on some 280ZX struts/brakes. B) Quote Link to comment
datsunfreak Posted May 2, 2017 Report Share Posted May 2, 2017 That guy knows what he's talking about... :rofl: But you didn't listen... B) Quote Link to comment
njoz1200ute Posted May 2, 2017 Author Report Share Posted May 2, 2017 In that era, 1200s and 120Ys would use the same struts/brakes. USDM "120Y"s used bigger struts/brakes, but not in other markets. Get some B310 control arms, steering knuckles, outer tie rods, and t/c rods. Put those on, then swap on some 280ZX struts/brakes. B) Okay did some research on the struts. Trying to plan for what to do with my front brakes. The tube is 45mm wide. The number on the strut is: 54303 H7405 AMPCO A search on the web tells me they are 120y struts. Is this correct? I was assuming 1200 coupe struts with disc brakes. I was beginning to research replacement parts but now I am in a bit of a roadblock. The calipers that came with the car look really poor and I have no idea if they are any good. I was just going to assume I need new calipers and hardware for the brakes. Whats your guys opinion here? Left side strut Measurement Brake rotor about 8.5" wide Right side strut Measurement Brake rotor about 8.5" wide Strut ID markings Calipers that came with car - unknown type I don't know for sure 100% but I would believe that these are 120y struts they came with the truck and both came from Australia Quote Link to comment
njoz1200ute Posted May 2, 2017 Author Report Share Posted May 2, 2017 "Note that B310 came with different size rotors and different size calipers. The A12-powered B310 used 45mm struts and smaller brakes which is slightly larger than B110." Off the other forum Quote Link to comment
datsunfreak Posted May 2, 2017 Report Share Posted May 2, 2017 which is slightly larger than B110 FYI, this describes every part Nissan ever made that wasn't for a 1200. :rofl: 1 Quote Link to comment
njoz1200ute Posted May 2, 2017 Author Report Share Posted May 2, 2017 That guy knows what he's talking about... :rofl But you didn't listen... B) Limited funds. I bought lots of new steering and suspension parts already. Yoo far in to change now But your are right i didn't listen Quote Link to comment
datsunfreak Posted May 3, 2017 Report Share Posted May 3, 2017 I bought lots of new steering and suspension parts already. Too far in to change now Why do you think my 1200 has 1200 struts in it? :P For now. :cool: Quote Link to comment
njoz1200ute Posted May 6, 2017 Author Report Share Posted May 6, 2017 Funny how things change. Rereading old threads I once had an L series engine (L18) and trans for this build (SSS stanza) I once had twin 40mm carbs, a gx head for this build.....no longer. Once had a rare console. Stock head and 32.36 carb. Ive downgraded heaps. That's life. Quote Link to comment
datsunfreak Posted May 6, 2017 Report Share Posted May 6, 2017 Funny how things change. Rereading old threads I once had an L series engine (L18) and trans for this build (SSS stanza) I once had twin 40mm carbs, a gx head for this build.....no longer. Once had a rare console. Stock head and 32.36 carb. Ive downgraded heaps. That's life. I might have you beat... :P Looking through my build thread, it goes... CA18DET (decided it was too complex for what I wanted so I sold off) KA24E (decided it was too heavy, but still have it) L18 (not sure why I flaked on this?) Ended up with a hot rod A15. Somehow simpler, yet more expensive than all the other options. :rofl: 1 Quote Link to comment
Ratwagon1600 Posted May 6, 2017 Report Share Posted May 6, 2017 It's a good question I was told by people on the other Forum that the struts or not 1200 but the struts are a from a 120y Maybe there is two different versions of a 120y strut and brake caliper? Is there two different versions with the us version of the B210? This link may help? http://datsun1200.com/modules/mediawiki/index.php?title=Strut_swaps Quote Link to comment
njoz1200ute Posted May 20, 2017 Author Report Share Posted May 20, 2017 Might have found a friend on the west coast willing to supply me brakes The ole ute is gettin dusty these days. Progress made. Seat belts installed. Rear loom repaired, there was some crusty wiring to repair. Retaped the loom and installed. License plate lights installed. Front and side indicators bulb changed cleaned amd installed. Shock absorbers. Excel G replacements from oz installed. Need some m12 split washers. Go fast rocker cover bolts installed that's all i can remember at the moment. The shock upper mounts were covered in Raptor liner so i had to buy an m12 1.25 die ans rethread them. Clearance was a pain but my trusty big ass adjustable wrench did the slow job okay. 2 Quote Link to comment
hobospyder Posted June 5, 2017 Report Share Posted June 5, 2017 Are the papers your check list? 1 Quote Link to comment
njoz1200ute Posted June 5, 2017 Author Report Share Posted June 5, 2017 Are the papers your check list? Sure is. The list is getting smaller, slowly Quote Link to comment
hobospyder Posted June 5, 2017 Report Share Posted June 5, 2017 well shit, that's a long list or you have some really big writting either way, i'm enjoying your endeavor, keep it up Quote Link to comment
njoz1200ute Posted June 5, 2017 Author Report Share Posted June 5, 2017 Thanks for following! 2 Quote Link to comment
njoz1200ute Posted September 22, 2017 Author Report Share Posted September 22, 2017 Had a friend lend me flares for a moment to test fit. I think they look cool but i decided i am not going down that road again. The General Ree i had to hire a shop to do it and help and it was a real pain. Good result but i dont like the idea of cutting into fresh fenders and quarter panels to make flares fit again. This is the correct shock absorber part number. I think someone was asking for that so here it is. Suspension installed. I returned the brakes i bought back to Rockauto since they were for bigger B210 version. My research shows that its possibly 76 and newer that uses the bigger caliper and rotor. Hence why it did not fit. Luckilly Stan was able to help me out and give me a pair of Raybestos refurbished calipers that were the right size When they arrived i fit them bit then I had a new problem. The rotors were rubbing the calipers and that was a no go. From my measurements it turned out that the rotors that came with my ute were 220mm in diameter. Rotors Caliper rub I decided to take the calipers apart to paint them. I bought a Duplicolor caliper kit to paint them. I have to say the paint goes on super thick. By brush. The paint took weeks to cure so beware. Put it on as thin as possible and don't follow the directions to recoat after 5 minutes.....let the first coat dry for a few days first then recoat. Or use a different product. Wagner brake hardware kit from rockauto. Paint. Reassembled ready for struts. I solved the rotor problem by researching that the correct size for the B110 or B120 is 212mm rotors. The difference of 8mm was causing the rubbing issue. I hired a shop to machine the rotors down to 212mm to fit. Success for now. Quote Link to comment
njoz1200ute Posted September 22, 2017 Author Report Share Posted September 22, 2017 I have been obsessed lately with the whole stickerbomb trend. I even joined a facebook group dedicated to it. If you ever want to get free stickers from somewhere all you have to do is ask! For a few months i have been contacting automotive companies and many were happy to send me stickers. One even sent me a whole decal kit for the entire car! So my inspiration led me and my toddler to start stickerbombing. First i started with the door handle estrucheons. Emojis! From cabinet grade plywood i made door panels next and continued the theme. Next I decided to think outside the box and do an exposed roof. I have never seen it done before on a 1200 so why not try. If i get tired of it then i can always cover it with a factory headlining. I coated the surface rust in POR 15 first. Painting it on a vertical surface is a real pain in the stomach. This is still a work in progress. 2 Quote Link to comment
njoz1200ute Posted September 23, 2017 Author Report Share Posted September 23, 2017 The next big hurdle in the building of this ute was the transmission mount and crossmember. For those that follow this thread you would recall that the factory mounts were removed from the body shell by the previous owner. Why? Probably because he was planning a CA or SR conversion and needed the extra room in the transmission tunnel. Unlucky for me. Keeping the tried and true A series motor with a 60a series 5 speed transmission requires those factory mounts. So what to do? Weld some donors? Seems too hard. Fabricate custom mount? First i headed down the road of fabricating my own crossmember like many others have done. I managed to get going on this but decided to look and see if there was another way. I studied the mount that someone had made for the 5 speed and noticed it was different than the usual B110 or B120 mount. The rubber isolater itself was different. From my research i discovered this isolator was from another model Datsun. This gave me an idea so i started researching other Datsun models and how the transmission mounts. My first idea was using a 510 crossmember. I managed to find one but when it arrived i discovered that the ends are sloped and would be too much work to try and make it work After more research I found out that the rubber isolator from my 5 speed is for a Z car. So i looked into this further. I found out that the 240z has a good looking crossmember that was flat not sloped like the 510. Finding a spare early 240z transmission crossmember was not easy. More research led me to find that Techno toy tuning makes an aftermarket Z car crossmember! So i purchased one and also a new 240z isolator. Using parts from my other Pitroad 5 speed mount i was able to slap together enough parts to make this work. The spacers and the flat face nuts were key to make this work. Installation begins. No more rope. The hardest part was getting the measurements correct and installing it square. To reinforce the bolts I used my beginning crossmember and chopped it up as plates. Done and dusted. Next problem. The driveshaft is 1 inch too long. The struggle never ends. 1 Quote Link to comment
datsunfreak Posted September 24, 2017 Report Share Posted September 24, 2017 Is this the Pit Road bracket/mount? Looks almost exactly like the one I built for mine. Using parts from my other Pitroad 5 speed mount i was able to slap together enough parts to make this work. The spacers and the flat face nuts were key to make this work. Quote Link to comment
njoz1200ute Posted September 24, 2017 Author Report Share Posted September 24, 2017 Maybe it's not. http://www.pitroad-ts.com/A-parts-2/mission/60mount.htm That's what i was told anyways Quote Link to comment
datsunfreak Posted September 24, 2017 Report Share Posted September 24, 2017 Maybe it's not. Well, the one you have (which is like mine) is for swapping from an auto to a 5spd, not from a 4spd to a 5spd. Floor mounts are different on auto cars. Quote Link to comment
