edekalil Posted July 30, 2019 Report Share Posted July 30, 2019 10 hours ago, mrbigtanker said: Untitled by raymond medeiros, on Flickr Untitled by raymond medeiros, on Flickr Dropped in and assembly begins. Don't laugh at its all I can afford. Sweet 1 Quote Link to comment
edekalil Posted July 30, 2019 Report Share Posted July 30, 2019 I still want that ride! 1 Quote Link to comment
Lockleaf Posted July 31, 2019 Report Share Posted July 31, 2019 On 7/29/2019 at 8:53 PM, mrbigtanker said: Untitled by raymond medeiros, on Flickr Hello This pic wierds my brain out. To the right of the motor, the car is clearly a different color than the engine, but to the left the car looks identical in color. Sweet new engine Tanker. 1 Quote Link to comment
Lockleaf Posted July 31, 2019 Report Share Posted July 31, 2019 (edited) Double post. Edited July 31, 2019 by Lockleaf Quote Link to comment
thisismatt Posted July 31, 2019 Report Share Posted July 31, 2019 29 minutes ago, Lockleaf said: This pic wierds my brain out. To the right of the motor, the car is clearly a different color than the engine, but to the left the car looks identical in color. Sweet new engine Tanker. Fender and door are not the same color. Not being critical, just sayin Quote Link to comment
datzenmike Posted August 1, 2019 Report Share Posted August 1, 2019 It's the light. Inside is probably florescent the back is daylight through the open door. All color is dependent on the light source. Why is it off the trailer?? Quote Link to comment
mrbigtanker Posted August 1, 2019 Author Report Share Posted August 1, 2019 2 hours ago, Lockleaf said: This pic wierds my brain out. To the right of the motor, the car is clearly a different color than the engine, but to the left the car looks identical in color. Sweet new engine Tanker. You are correct, the door was the only rust and i had it all repaired, my fault on off color. 2 hours ago, thisismatt said: Fender and door are not the same color. Not being critical, just sayin you said right, for once 7 minutes ago, datzenmike said: It's the light. Inside is probably florescent the back is daylight through the open door. All color is dependent on the light source. Why is it off the trailer?? Because it does run funny Canadian. 1 Quote Link to comment
mrbigtanker Posted August 5, 2019 Author Report Share Posted August 5, 2019 Untitled by raymond medeiros, on Flickr This troy Amish header is a bitch to get in. You have to [ull all the steering out to install, never again. And then I fucked up by having the o2 sensor bung in wrong place. Easy fix but shit man. 1 Quote Link to comment
mrbigtanker Posted August 5, 2019 Author Report Share Posted August 5, 2019 By the way that's the before picture, I did not take another pic because I was pissed. 1 Quote Link to comment
Jesse C. Posted August 5, 2019 Report Share Posted August 5, 2019 13 hours ago, mrbigtanker said: This troy Amish header is a bitch to get in. You have to [ull all the steering out to install, never again. And then I fucked up by having the o2 sensor bung in wrong place. Easy fix but shit man. Troy who? 2 4 Quote Link to comment
mrbigtanker Posted August 6, 2019 Author Report Share Posted August 6, 2019 (edited) Untitled by raymond medeiros, on Flickr Untitled by raymond medeiros, on Flickr Untitled by raymond medeiros, on Flickr Wow what a fuckin headache that header was, but all fixed now, relocated the Bung hole yes I said it. And got it in Literally. Manifold was just mocked up. Just got some bullshit things to do, like vacuum balance tube for the ITB's, New throttle cable mount, hmmmm and I need to machine the inside of that super whammer jammer thermostat housing as it does not have one. How ever I found a 180 degree Chevy sprint one that will work, just need to machine the inside hole just a little to make flush, and whoa-la its in like Flynn. Not perfect but should scoot a little and man that Kameari chain tensioner will be a ear sore, maybe. Disclaimer that valve cover is just for looks, My old bright red one is going back in just having the powder job re done.Helps hide the ugliness of this wagon. Edited August 6, 2019 by mrbigtanker 1 1 Quote Link to comment
Duncan Posted August 6, 2019 Report Share Posted August 6, 2019 That header DOES look like a pain in the ass to get in there. It looks good from my house! 2 Quote Link to comment
tr8er Posted August 7, 2019 Report Share Posted August 7, 2019 I’m sure the rack and pinion setup would solve that clearance issue right on up. Haha 1 1 Quote Link to comment
mrbigtanker Posted August 9, 2019 Author Report Share Posted August 9, 2019 Untitled by raymond medeiros, on Flickr Untitled by raymond medeiros, on Flickr Making all new MSD spark plug wires and vacuum balancer to Map sensor is made. 2 Quote Link to comment
tr8er Posted August 9, 2019 Report Share Posted August 9, 2019 Isn’t it odd that better looking boots don’t exist? You picked same as me, but I thought there should be better. 2 Quote Link to comment
thisismatt Posted August 9, 2019 Report Share Posted August 9, 2019 Why does everything look so dry? No oil or assembly line on anything? 1 Quote Link to comment
datzenmike Posted August 9, 2019 Report Share Posted August 9, 2019 ... she said. 1 Quote Link to comment
mrbigtanker Posted August 10, 2019 Author Report Share Posted August 10, 2019 21 hours ago, tr8er said: Isn’t it odd that better looking boots don’t exist? You picked same as me, but I thought there should be better. Yeah thats about as good as it gets 15 hours ago, thisismatt said: Why does everything look so dry? No oil or assembly line on anything? It is on the dry side but its covered. 13 hours ago, datzenmike said: ... she said. Please spit. 1 1 Quote Link to comment
Rick-rat Posted August 10, 2019 Report Share Posted August 10, 2019 (edited) 16 hours ago, thisismatt said: Why does everything look so dry? No oil or assembly line on anything? Invisible oil Edited August 10, 2019 by Rick-rat 1 Quote Link to comment
thisismatt Posted August 10, 2019 Report Share Posted August 10, 2019 46 minutes ago, mrbigtanker said: Yeah thats about as good as it gets It is on the dry side but its covered. Please spit. I mean for first start-up. Looks like it needs some assembly lube on the cam at least 1 Quote Link to comment
mrbigtanker Posted August 10, 2019 Author Report Share Posted August 10, 2019 5 hours ago, thisismatt said: I mean for first start-up. Looks like it needs some assembly lube on the cam at least Matt, its all good, I have it ready to go. Valve cover in powder shop still doing intake manifold mods. Have more KY standing by and break in oil also. All good in the hood. 1 Quote Link to comment
mrbigtanker Posted August 14, 2019 Author Report Share Posted August 14, 2019 Untitled by raymond medeiros, on Flickr Sure does not look like my hood is going to clear when valve cover is mounted. Quote Link to comment
