mrbigtanker Posted May 4, 2015 Author Report Share Posted May 4, 2015 did u test your tube of anal ease for viscosity break down versus friction Not worth it at all John even on sale. Switched to all natural spit and so far no break down. What we concluded was when it starts to get dry we just supplied more spit. Let me know if you need help with this. 2 Quote Link to comment
tr8er Posted May 4, 2015 Report Share Posted May 4, 2015 Working on changing it up just a bit. What's with the tee fitting on the pressure sensor? Any reason for that? Looks or function? Just curious. And the 1 Quote Link to comment
tr8er Posted May 4, 2015 Report Share Posted May 4, 2015 And fuck all this oil filter business. Just install a seperate 100gallon oil tank and just dump it on the road as you go. No cycling, no risk of contamination. It would cost a little more to drive it, but that's what trailers are for right?? 1 Quote Link to comment
mrbigtanker Posted May 5, 2015 Author Report Share Posted May 5, 2015 What's with the tee fitting on the pressure sensor? Any reason for that? Looks or function? Just curious. And the I got it from Joe installed already, I might pull it. Quote Link to comment
shacks510 Posted May 5, 2015 Report Share Posted May 5, 2015 Well it's not a Fram filter how ever why would you give a shit what filter. I have used them with no problems myself.. This is Ratsun and these guys all run high horsepower Lblocks or something.. If a Fram is good enough for David Frieburgers 1500hp Camaro, then they're good enough for our 150hp junk. Quote Link to comment
maltese Posted May 5, 2015 Report Share Posted May 5, 2015 If a Fram is good enough for David Frieburgers 1500hp Camaro, then they're good enough for our 150hp junk. Yeah. I'm sure he runs a Fram Racing filter on his car....(not the same as their orange box crap) ....for all of a couple miles between changes. Quote Link to comment
MicroMachinery Posted May 5, 2015 Report Share Posted May 5, 2015 If a Fram is good enough for David Frieburgers 1500hp Camaro, then they're good enough for our 150hp junk. False. Quote Link to comment
tr8er Posted May 5, 2015 Report Share Posted May 5, 2015 If a Fram is good enough for David Frieburgers 1500hp Camaro, then they're good enough for our 150hp junk. Camaros are the perfect Fram application. 2 Quote Link to comment
skyblue Posted May 5, 2015 Report Share Posted May 5, 2015 Who cares. If tanker wants to run fram, it's his car. Quote Link to comment
heywier427 Posted May 5, 2015 Report Share Posted May 5, 2015 He skimps on everything else, so... Quote Link to comment
mrbigtanker Posted May 5, 2015 Author Report Share Posted May 5, 2015 He skimps on everything else, so... Thats true all garbage is what i drive.. Quote Link to comment
Mattndew76 Posted May 5, 2015 Report Share Posted May 5, 2015 I smell hateraid. 1 Quote Link to comment
jrock4224 Posted May 5, 2015 Report Share Posted May 5, 2015 like i always hear people say fram sucks but then i never see threads that say my motor is fubar cause fram ... i dont use them but have way back .,... my boat motor ran two of them ... makes about 600 hp... but broke a rod cause fords stupid oil bump design broke the casting snapped them pump of and starved the motor till bearing failure and now i have a john kaase oil pump to keep a stupid bbf from eating it self again i dont endorse fram but i have seen and had some crazy stuff use fram .... so hating a guy for having one is just bandwagon ... i hate ray fo other reasons ... mostly having arms the size of my legs 1 Quote Link to comment
tr8er Posted May 5, 2015 Report Share Posted May 5, 2015 I say: if you won't use it on your dialysis machine, why would you use it on your car.... If Fram knows their rep is fuct, they would likely either try to improve their rep through better product with ad campaign showing the new, start a new branch with a new name with better product, or just focus their target on the. Shrinking market of people who change their own oil. Quote Link to comment
jrock4224 Posted May 5, 2015 Report Share Posted May 5, 2015 is there a wagon in this thread lol 1 Quote Link to comment
shacks510 Posted May 5, 2015 Report Share Posted May 5, 2015 Damn, I give Ray a hard time about the Fram he doesn't have, now look! 3 Quote Link to comment
jrock4224 Posted May 5, 2015 Report Share Posted May 5, 2015 cuz ratsun and jorts 2 Quote Link to comment
datrod Posted May 5, 2015 Report Share Posted May 5, 2015 Cause he is a big target. Easy to pick on his ass. because it's huge. 3 Quote Link to comment
mrbigtanker Posted May 5, 2015 Author Report Share Posted May 5, 2015 Cause he is a big target. Easy to pick on his ass. because it's huge. Fucker. Quote Link to comment
datrod Posted May 7, 2015 Report Share Posted May 7, 2015 That's a nice piece. I have one just like it. Some big target hooked me up with it. 1 Quote Link to comment
mrbigtanker Posted May 7, 2015 Author Report Share Posted May 7, 2015 Thank you Datrod.Old school meets up with a new twist.And yes the vents in the back now. 3 Quote Link to comment
earlyvws Posted May 7, 2015 Report Share Posted May 7, 2015 What needs to be done to put the vent in the back. I know welding up old hole but anything special about vent relocation? 1 Quote Link to comment
datrod Posted May 7, 2015 Report Share Posted May 7, 2015 earlyvws. Not really, Just make sure you put some kind of baffle on the inside. So the oil doesn't go poring out I welded an AN fitting on the back side of Mr Big's valve cover. With a piece of aluminum sheet metal for a baffle. That way he can plum it to a catch can, 4 Quote Link to comment
