DanielC Posted January 5, 2016 Report Share Posted January 5, 2016 One advantage of the five speed being a slip yoke transmission is the measurement of the front half of the drive line does not need to be exact. By the way, I could still remove the five speed from under the truck, leaving the engine in, to work on the clutch, but you have to remember to drain the transmission first. 2 Quote Link to comment
HOGIE Posted January 5, 2016 Author Report Share Posted January 5, 2016 One advantage of the five speed being a slip yoke transmission is the measurement of the front half of the drive line does not need to be exact. By the way, I could still remove the five speed from under the truck, leaving the engine in, to work on the clutch, but you have to remember to drain the transmission first. Or rusty floors. But that is yet to be determined. PO put a carpet mat done with some sort of adhesive and it's in there pretty good 1 Quote Link to comment
DanielC Posted January 5, 2016 Report Share Posted January 5, 2016 The best part of "mystery carpet adhesive" is figuring out the solvent to remove it, and then getting the personal protection equipment to protect yourself from the solvent. 2 Quote Link to comment
Charlie69 Posted January 5, 2016 Report Share Posted January 5, 2016 Hogie however you mod your transmission mount be sure to use all four bolts to connect it to the cross member. 1 Quote Link to comment
HOGIE Posted January 5, 2016 Author Report Share Posted January 5, 2016 The best part of "mystery carpet adhesive" is figuring out the solvent to remove it, and then getting the personal protection equipment to protect yourself from the solvent. Using adhesive remover with PPE, that takes all the fun out of it. JK I've used that type of stuff plenty of times and have a vapor respirator and know to maintain ventilation. Thanks Hogie however you mod your transmission mount be sure to use all four bolts to connect it to the cross member.Check 1 Quote Link to comment
HOGIE Posted January 10, 2016 Author Report Share Posted January 10, 2016 So I think this is the FS5W71B trans I measured it and it was right around 30". You tell me First two pics are my trans The second two pics are from a Mike post showing the FS5W71B In this shot the front and back look very different in the rear section. Mine looks like the back trans. I think mine looks just like this one 1 Quote Link to comment
Charlie69 Posted January 10, 2016 Report Share Posted January 10, 2016 Hogie, check for model # here. Some trans have it stamped there. 1 Quote Link to comment
HOGIE Posted January 10, 2016 Author Report Share Posted January 10, 2016 Hogie, check for model # here. Some trans have it stamped there Thanks Charlie. I looked all over the rear case and sides of the front case but overlooked the top of the bell This was much faster than the tells what this is game I was expecting 1 Quote Link to comment
Charlie69 Posted January 11, 2016 Report Share Posted January 11, 2016 If your trans is not marked Datzenmike is great at identifying them. Quote Link to comment
flatcat19 Posted January 11, 2016 Report Share Posted January 11, 2016 I think the speedo hole mounting has something to do with it. Take a pic. 1 Quote Link to comment
wayno Posted January 11, 2016 Report Share Posted January 11, 2016 It looks like a pre 1980 Datsun 620 5 speed to me, although it could have been put in a car also, just one made before 1980 without the reverse lockout. You can always tell it was made before 1980 because of the gussets on the sides of the transmission like in the photo below. 1 Quote Link to comment
HOGIE Posted January 14, 2016 Author Report Share Posted January 14, 2016 Numbers on bell housing. Serial#? Numbers on rear housing. Dafuq? Measured from front of bell housing to.... Perspective is directly above output shaft 1 Quote Link to comment
flatcat19 Posted January 14, 2016 Report Share Posted January 14, 2016 I think the speedo hole mounting has something to do with it. Take a pic. I'm a little surprised Mike has not jumped in and ID'd this thing. 2 Quote Link to comment
HOGIE Posted January 14, 2016 Author Report Share Posted January 14, 2016 Found these Doesn't say anything about serial numbers but based on the info that breaks down the abbreviations I have a: F - floor shift S- special overdrive (5th gear) 5- 5spd ?- dunno #- dunno B- from pictures So it's likely the standard FS5W71B Mobile version will need a magnifying glass 2 Quote Link to comment
HOGIE Posted January 15, 2016 Author Report Share Posted January 15, 2016 I'm a little surprised Mike has not jumped in and ID'd this thing. I was thinking the same thing Speedo hole 1 Quote Link to comment
HOGIE Posted February 5, 2016 Author Report Share Posted February 5, 2016 I have these three wheel ( really 4, two with oval slot). They are all slightly different. For instance two with the oval slot, one has larger flat-ish hub cap pegs and they all have different curvature. Can anyone ID? Also just another photobucket bitch. Only want to grab 3 link addresses and had to close the browser like 8 times because it kept changing to a bs Facebook add/' random winner' page Uuhg! 2 Quote Link to comment
Draker Posted February 5, 2016 Report Share Posted February 5, 2016 What am I looking at here? 1 Quote Link to comment
HOGIE Posted February 5, 2016 Author Report Share Posted February 5, 2016 Had to upload in installments. Photobucket+ ratsun mobile version Refresh to view edit 1 Quote Link to comment
Draker Posted February 5, 2016 Report Share Posted February 5, 2016 Photobucket sucks.. but that's what I use too. Painful at times. 2 Quote Link to comment
hobospyder Posted February 5, 2016 Report Share Posted February 5, 2016 I think the flats pegs are 521 stock wheels. They all look like stock wheels though just different models. 1 Quote Link to comment
Eagle_Adam Posted February 13, 2016 Report Share Posted February 13, 2016 Nice truck man, hopefully I can come see It 1 Quote Link to comment
HOGIE Posted February 14, 2016 Author Report Share Posted February 14, 2016 Nice truck man, hopefully I can come see It Thanks man. I want to see it too. It's been parked at a friends house for a while now but a plan to move it back so I can put all the prices together is in the works You still around Eugene/Springfield? 1 Quote Link to comment
Eagle_Adam Posted February 14, 2016 Report Share Posted February 14, 2016 Not right now, life's nuts 1 Quote Link to comment
tdaaj Posted February 20, 2016 Report Share Posted February 20, 2016 Top wheel is Chevy luv or maybe early 60's datsun, middle wheel is 320/50/521, bottom wheel is drum brake 620 1 Quote Link to comment
HOGIE Posted February 20, 2016 Author Report Share Posted February 20, 2016 Top wheel is Chevy luv or maybe early 60's datsun, middle wheel is 320/50/521, bottom wheel is drum brake 620 Thanks man 1 Quote Link to comment
