wiring specialties Posted February 9, 2015 Report Share Posted February 9, 2015 Hello fellow Ratun'ers Our S13 SR20DET engine and transmission harnesses (OEM SERIES) are back in stock. Quantities are limited and the last sets sold very quickly. If you are looking for a brand new wiring harness that will completely replace every wire connector and ground then this is the harness for you. No splicing or modifications required - OEM fit and finish with a STARTUP GUARANTEE. Engine harness: $319 - - Transmission Harness: $99 - - Combo Harness: $409 Order here: [url=http://www.wiringspecialties.com/s13sr20det.html]http://www.wiringspecialties.com/s13sr20det.html[/url] - photo courtesy of John Huckins - Team Wiring Specialties Wiring Specialties Harness Features: - Plug and play- No cores or additional wiring required- Point to point continuity checked- Constructed using brand new OEM connectors and seals- Improved grounding - Retains OEM wiper functionality- Retains Cruise Control and all gauge functions including speedo and tach- Works with the Greddy/Freddy intake manifolds- All A/C, Temp override, Auto On/Off functions properly- OEM wiring connections and 'T' junctions. No soldered connections at all 1 Quote Link to comment
DREWSDIME Posted April 26, 2015 Report Share Posted April 26, 2015 Do you make a harness for KA24DE OBD2 to 510? Quote Link to comment
72nismo Posted June 26, 2017 Report Share Posted June 26, 2017 Do you make a harness for KA24DE OBD2 to 510? Hey Drew when you get a chance PM or check your PM's i sent you a message. Thanks 1 Quote Link to comment
