r0p0doe Posted August 22, 2016 Report Share Posted August 22, 2016 stay away from 8" wide wheels with that car please I'm running 8"... 2 Quote Link to comment
That4doorKiD Posted August 22, 2016 Author Report Share Posted August 22, 2016 Don't worry mate, flares are ugly in my taste. The most damage I'll do is a slight fender pull lmao. And remove the inner bump. 2 Quote Link to comment
shacks510 Posted August 22, 2016 Report Share Posted August 22, 2016 flares are ugly in my taste gee, thanks 2 Quote Link to comment
That4doorKiD Posted August 23, 2016 Author Report Share Posted August 23, 2016 gee, thanks what i meant to say is that i have a four door.. you got a 2 door remember B) Quote Link to comment
That4doorKiD Posted August 23, 2016 Author Report Share Posted August 23, 2016 https://www.pinterest.com/pin/71916925272014204/ goals, 14x8 -13 wheels maybe not so much tuck. but slammed 4 dour like this especially 68 ganggg my dream wheels but i'll settle for some Rotas for now...I'm broke Quote Link to comment
shacks510 Posted August 23, 2016 Report Share Posted August 23, 2016 8j -13 would be the equivalent of a 9j +0. That's a lot under stock fenders, and tire choices suck. Cheap wheels is more expensive than keeping the wheels you already have. Get tires for the swastikas and run those if anything. 1 Quote Link to comment
That4doorKiD Posted August 23, 2016 Author Report Share Posted August 23, 2016 True, maybe 8 0offset will do I think swaztikas only go good on two doors, when they have Supersonic Grills Quote Link to comment
shacks510 Posted August 24, 2016 Report Share Posted August 24, 2016 You have stock struts... Look at your 7" wide front wheel. Think about how much more an 8" would poke out, especially with negative offset, and a slightly taller tire. You'd have no room to go any lower without filleting your tire, and/or an absurd amount of negative camber. You should work on finding 280zx struts/brakes. Narrow your front track, and more importantly, have better brakes. Some things are more important than others. Prioritize. 1 Quote Link to comment
r0p0doe Posted August 24, 2016 Report Share Posted August 24, 2016 You should work on finding 280zx struts/brakes. Narrow your front track, and more importantly, have better brakes. Some things are more important than others. Prioritize. True, maybe 8 0offset will do I think swaztikas only go good on two doors, when they have Supersonic Grills Swastikas on four doors are a no no He's correct man, get you a set of 280zx struts and your good to go. You'd be able to get 8" wide in the front no problem, I'm 8" with no offset in the rear. I could of done the same for the front but I wanted to stagger for a certain look, if you don't go 280zx you will def poke going wider than 7" Quote Link to comment
That4doorKiD Posted August 24, 2016 Author Report Share Posted August 24, 2016 Yes forgot to mention, that's going in the package for sure. I didn't forget that Quote Link to comment
shacks510 Posted August 24, 2016 Report Share Posted August 24, 2016 Oh, and here's a four door with swastikas, just for reference. Here's the rest of that thread. His final outcome looked really good. http://community.ratsun.net/topic/64684-whats-the-best-color-wheel-for-butterscotch-paint/ Quote Link to comment
