]2eDeYe Posted September 26, 2008 Report Share Posted September 26, 2008 Never had a problem hammering on the plastic tool. :D This is from the last time I did the clutch in the Jeep, but it's the same process. As you can see, I didn't need any more grease or oil under there :lol: Quote Link to comment
Llittle_Llama Posted September 26, 2008 Report Share Posted September 26, 2008 lol, i thought that was lynch posting pics cause he said he posted them in his other thread and i was likr "what the hell? when did you lift the datto?" Quote Link to comment
lynchfourtwenty Posted September 26, 2008 Author Report Share Posted September 26, 2008 lol good luck! Quote Link to comment
jetdoc1971 Posted September 27, 2008 Report Share Posted September 27, 2008 it was a huge pain in the ass to get the tranny out with that fucking header i have.. son of a bitch is totaly in the way... HEY whats the trick to gettin the fly wheel off without the engine turning?? it needs resurfaced like a mofo Pull a sparkplug and feed about 10 feet of 1/4" nylon rope into the cylinder. When the piston comes up to TDC it will lock up on the SOFT rope and enable you to break loose the flywheel bolts. When you are done back the engine up a bit and extract the rope. Quote Link to comment
moparvwfreak Posted September 28, 2008 Report Share Posted September 28, 2008 Pull a sparkplug and feed about 10 feet of 1/4" nylon rope into the cylinder. When the piston comes up to TDC it will lock up on the SOFT rope and enable you to break loose the flywheel bolts. When you are done back the engine up a bit and extract the rope. i have heard about that trick as well. but it was for something else. oh yeah crank pulley. good idea all in all though. keeps everything frome getting screwed up. Quote Link to comment
lynchfourtwenty Posted September 28, 2008 Author Report Share Posted September 28, 2008 datsunmike also reccomended it for changin valve seals without removing the head Quote Link to comment
tdaaj Posted September 28, 2008 Report Share Posted September 28, 2008 2eDeYe;83194']Soap. Search 'hydraulic method' for a bit more info if what's below doesn't make sense. Smash some bar soap in the hole. Use your clutch alignment tool in the hole and hit it with a rubber mallet to smash the soap in some more. Pack more soap in there' date=' hit the alignment tool and hammer. Eventually the soap will push out the bushing. Scrape out the soap install your new bushing.[/quote'] grease works too, hell in a pinch i've used gojo Quote Link to comment
