MicroMachinery Posted May 10, 2015 Report Share Posted May 10, 2015 Don't even wash it. 1 Quote Link to comment
DanielC Posted May 11, 2015 Report Share Posted May 11, 2015 No spark is more likely bad points. Check for power on the positive side of the coil. You should have power, using a test light. If you do, check for power on the negative side of the coil. The points just ground the coil. if the points are closed, the test light on the negative side of the coil should not light up. But when the points are open, the test light on the negative side of the coil should come on. 2 Quote Link to comment
ArchetypeDatsun Posted May 12, 2015 Author Report Share Posted May 12, 2015 The starter sylinoid is screwed on the starter and have start it with a flat head screwdriver with the choke barley out since it has a weber style carb Idles a bit high but starts and even moves on its own power. 1 Quote Link to comment
thisismatt Posted May 12, 2015 Report Share Posted May 12, 2015 I'll pay you double...no, triple, what you paid for it :P 1 Quote Link to comment
ArchetypeDatsun Posted May 12, 2015 Author Report Share Posted May 12, 2015 Lol 1 Quote Link to comment
gene knight Posted May 14, 2015 Report Share Posted May 14, 2015 Hey congrats on getting the 521 1 Quote Link to comment
ArchetypeDatsun Posted May 15, 2015 Author Report Share Posted May 15, 2015 I wasn't going to wash it but I said what the heck. Finding out the color isn't original but someone did a good job painting it. 2 Quote Link to comment
MicroMachinery Posted May 15, 2015 Report Share Posted May 15, 2015 Don't even wash it. I wasn't going to wash it but I said what the heck. 2 Quote Link to comment
gene knight Posted May 15, 2015 Report Share Posted May 15, 2015 Looks good on the outside but needs some tlc in the engine bay and a spray in bedliner,maybe a little touch up to the interior 1 Quote Link to comment
ArchetypeDatsun Posted May 17, 2015 Author Report Share Posted May 17, 2015 Yeah once I have more money rolling in it will get more attention. 1 Quote Link to comment
