Farmer Joe Posted January 25, 2015 Report Share Posted January 25, 2015 gonna be making a set of coilovers for our 411. datsun parts LLC is selling a coilover kit for the 210 struts i have. they are 200lb springs. soo, whats some input on spring rates on the front of datsun cars? 200lbs gonna be too stiff, or just right? it will have an L engine and trans as a side note. and probably no sway bar. thanks for the advice. Quote Link to comment
INDY510 Posted January 25, 2015 Report Share Posted January 25, 2015 anything stiffer than #200 apparently requires WAY more expensive shocks .. If I didn't want to be super low I would have gone with #200 springs on my 510. My #225's are almost too stiff for bumpy roads, and that's with $375 adjustable KONI yellow shocks. A 411 is probably lighter than a 510, so #200 should be perfect. And you can use some $100 shocks with #200 springs. 1 Quote Link to comment
Farmer Joe Posted January 25, 2015 Author Report Share Posted January 25, 2015 would the 200lb rate work with the stock 210 strut insert? with how small the car it, im wanting to build a set of really short struts using some mr2 or mk2 inserts so i dont end up with gaudy strut towers under the hood. Quote Link to comment
Lozer Posted January 26, 2015 Report Share Posted January 26, 2015 Lol im running 450's on the front of my goon and its awesome (for my chiropractor) 1 Quote Link to comment
