84 4x4 720 trans swap
720jon
OK. Here's one for you. 84 4x4 720 trans grenaded yesterday. I bought a trans out of a 93 2wd hardbody. The trans in mine is the short one, the one I got is long. I know I need to shorten the shaft between the trans and t case but I have to get to work (33 miles) to do it. I know it's a lot of extra work (but I need it driving by Monday) but can I take the t case out and install a 2wd driveline to make it work? P.s. engine is running AWESOME! After I rebuilt it i knew the trans was going to be the next to go lol
  • Replies 12
Wayno the primary driveshaft between the transmission and the transfer case is only at most a couple of feet. You you need do is carefully measure the two transmission lengths and subtract. The difference is how much to shorten it.
He is talking about removing the transfer case and basically making it a 2wd with a 2 piece driveline, that was what I was referring to.
Oh.. right.. so shortening/balancing a driveline, aligning the trans and transfer case and making it work would be cheaper and quicker than using the right trans. Gotcha.
:D
