Dad gave me his old 74 620 got alot of work to do
lbrooks6174
http://20150104_174645_zpsntcgx2ah.jpghttp://
20150104_174655_zpsnpsepf0k.jpghttp://
20150104_174702_zps9f50rb1d.jpghttp://
Done so far
fuel tank cleaned
Carb rebuilt
new plugs
oil change
replaced leaking a/m oil pressure gauge with factory sending unit "light still works "
new wheel cylinders and brake hoses
rewired I/R alternator correctly "choke now works"
4 new 195/75R14 Hankook tires
got it purring like a kitten
driving it home this weekend and I will post better pics
got some rusted panels i.e. floor pans, rockers lower door skins, and battery tray. but not to far gone
Link to post
  • Replies 58
planning on keeping it as stock as possible with a few minor upgrades, I am having issues with the Hitachi  carb not wanting to idle, I believe it has picked up some trash from the feed line from the pump. today I picked up a new fuel pump and Sunday I will clean carb again hope it will fix the idle issue I have found this carburetor is very temperamental but it is 41 years old.
Link to post
Before you install and run the new fuel pump it would be a good idea to drop the fuel tank and clean it and the lines out.  They are notorious for being rusty.  The crap in the carb came from the tank and lines  most likely.
Link to post
this times like 1000
Link to post
  • 4 weeks later...
Looks like some one found some goodies. That's a nice bezel. It is hard to find one that has not been hacked up. I would try to find an original radio and install it and if you want to put a higher end on I would put it in the glove compartment.
Link to post
  • 4 weeks later...
figure an update is in order been doing a lot of electrical works dash lights gauges and external lights installed my new dash trim. it had a broken exhaust pipe fixed that and while under there noticed center support bearing was shot so i replaced that to. then alternator took a dump replaced that. I am happy to say i drove it to work today 31 miles one way it drove great i do need to tweak the throttle return spring. snapped some pics while at work figured its a fitting place to take it.
20150316_195622_zpssywalok5.jpg20150316_195554_zpsr2nqg1ei.jpg20150316_195004_zpsernprind.jpg20150316_194939_zpsmg83baky.jpg20150316_194927_zpsuayhokoq.jpg20150316_195017_zpstcwbjxfu.jpg20150316_195023_zpstf2awfce.jpg20150316_195050_zpscasybbdq.jpg20150316_195102_zpsad6n0q2q.jpg20150308_184446_zpsth07srwc.jpg
  • Like 3
Link to post
  • 4 weeks later...
