ariascarlos1990 Posted October 1, 2008 Author Report Share Posted October 1, 2008 yes the truck is level when we do it. yeah but, I dont see how it went bad. When we took it off a truck at U-Pull it and the brakes on it where very good. :confused: Quote Link to comment
lynchfourtwenty Posted October 1, 2008 Report Share Posted October 1, 2008 he meant bad from the store, if its a used one it isnt technicly "New" Quote Link to comment
datzenmike Posted October 1, 2008 Report Share Posted October 1, 2008 I'm a big fan of used. If they sit they can still age and as soon as you start using them the rubber seals leak. Quote Link to comment
lynchfourtwenty Posted October 2, 2008 Report Share Posted October 2, 2008 you can get a remanned MC at my local part store for like 22 bux, thats providing you use your oregon id, if not its like 24-25.. an i think you have to take them your old one.. either way its a cheap easy fix if thats the problem, jus not sure how long the remanned ones last Quote Link to comment
ariascarlos1990 Posted October 2, 2008 Author Report Share Posted October 2, 2008 True True. p.s. We just noticed some kind of air leak comming from between the MC and the booster! is there supposed to be a gasket inbetween those two? Quote Link to comment
lynchfourtwenty Posted October 2, 2008 Report Share Posted October 2, 2008 not to my knowlege, you want that area to be clean tho... also it sounds like the seals maybe blown an its pushin air out the back instead of fluid out the front.. i would just spend the money an get a new or even a reman'd MC, like i said they're cheap at my local place.. call around see if you can get one for 25bux or so Quote Link to comment
ariascarlos1990 Posted October 2, 2008 Author Report Share Posted October 2, 2008 ok. will do. Quote Link to comment
