atomman Posted January 16, 2015 Report Share Posted January 16, 2015 Thought I share what I've been working on for my 240Z I wanted and adjustable top mount that fitted the original mounting hole becuase i didn't want to cut them, so i designed these, A bit of machining time in work, fitting them up now the LCA are back to there original place even though the car is pretty low, The RCA's or bump steer bushes have a 25mm offset which also in creases the track on the front, from a couple of quick measurements I have + - 5 degrees of adjustment on the front which should be ok for road and occasional track use. Cheers Gary 2 Quote Link to comment
dscottdatsun Posted January 17, 2015 Report Share Posted January 17, 2015 Nice work. :thumbup: 1 Quote Link to comment
Datsubishi Posted June 27, 2015 Report Share Posted June 27, 2015 I don't know why this thread didn't get more love. Kudos on the machine work Atomman! That's an incredible idea for bump steer spacers. Get a wider track and correct some LCA geometry at the same time. Clean idea and install on the upper strut mounts as well. Quote Link to comment
