the510keeper Posted September 2, 2016 Author Report Share Posted September 2, 2016 14 Quote Link to comment
q-tip Posted September 2, 2016 Report Share Posted September 2, 2016 Look at all that beautiful caster.... 3 Quote Link to comment
jrock4224 Posted September 2, 2016 Report Share Posted September 2, 2016 Look at all that beautiful caster.... hats alot 1 Quote Link to comment
the510keeper Posted September 6, 2016 Author Report Share Posted September 6, 2016 Ok kids, drives great, :) 5 Quote Link to comment
carterb Posted September 7, 2016 Report Share Posted September 7, 2016 That place caught my eye coming home from Depot Bay last year. The owner (?) has a website: http://bluebirdstation.weebly.com/ Looks like she is an artsy-fartsy type. I thought about contacting her to see if she'd be interested in doing a painting of my car in front of her place pretty much just like you shot in your photograph. --carter 3 Quote Link to comment
the510keeper Posted September 11, 2016 Author Report Share Posted September 11, 2016 That sounds great Carter :) FauxBird back under the knife, While being as low as she has been we completely fucked the oil pan. But Chris Metal guy is the man and got tired of her leaking on his floor. 10g 8 Quote Link to comment
Draker Posted September 11, 2016 Report Share Posted September 11, 2016 That will certainly help! 2 Quote Link to comment
shacks510 Posted September 12, 2016 Report Share Posted September 12, 2016 Make the pan and pickup shallower so it's above the crossmember. Adding a steel plate will only make it that much closer to the ground and make it buckle somewhere else. A little bit shallower wouldn't hurt unless you're thrashing it and starving the engine when the oil sloshes around. 2 Quote Link to comment
r0p0doe Posted September 12, 2016 Report Share Posted September 12, 2016 Make the pan and pickup shallower so it's above the crossmember. Adding a steel plate will only make it that much closer to the ground and make it buckle somewhere else. A little bit shallower wouldn't hurt unless you're thrashing it and starving the engine when the oil sloshes around. Mine is working out fine... 1 Quote Link to comment
metalguy541 Posted September 12, 2016 Report Share Posted September 12, 2016 The engine has been raised from where it was before only occasionally hitting the ground from the looks of it... but the previous repair leaked, so that is what i fixed and added the skid plate just in case 4 Quote Link to comment
ol' 320 Posted September 12, 2016 Report Share Posted September 12, 2016 The engine has been raised from where it was before only occasionally hitting the ground from the looks of it... but the previous repair leaked, so that is what i fixed and added the skid plate just in case Do you have a bigger pic you could post? I'm interested in seeing more of this fix:) 1 Quote Link to comment
shacks510 Posted September 12, 2016 Report Share Posted September 12, 2016 Mine is working out fine... I have a comp pan that sits 1/2" ABOVE the crossmember so I don't have any issues :) 1 Quote Link to comment
metalguy541 Posted September 12, 2016 Report Share Posted September 12, 2016 Do you have a bigger pic you could post? I'm interested in seeing more of this fix:) Of what fix? I just beat the pan back to flat and welded up the leaks and added the plate. I think he said the motor got raised with different mounts last go around. 1 Quote Link to comment
ol' 320 Posted September 12, 2016 Report Share Posted September 12, 2016 ok. I thought you made the pan shallower. 1 Quote Link to comment
AtomChurch Posted September 12, 2016 Report Share Posted September 12, 2016 How the fuck did I miss this!? Fantastic. I love the scratch marks of the scotchbrite in in specific directions. Good work. 1 Quote Link to comment
kerleybird Posted September 12, 2016 Report Share Posted September 12, 2016 Fucking solid man! Keep up the good work! 1 Quote Link to comment
r0p0doe Posted September 12, 2016 Report Share Posted September 12, 2016 I have a comp pan that sits 1/2" ABOVE the crossmember so I don't have any issues :) Cus you aint that low :fu: :rofl: 2 Quote Link to comment
jrock4224 Posted September 12, 2016 Report Share Posted September 12, 2016 Cus you aint that low :fu: :rofl: :angel: :blush: B) 1 Quote Link to comment
ArchetypeDatsun Posted November 8, 2016 Report Share Posted November 8, 2016 Ok kids, drives great, :) Fucker you were in my town and didn't hit me up... Quote Link to comment
the510keeper Posted November 8, 2016 Author Report Share Posted November 8, 2016 Dude I'm n ur town once a week, but usually early am driving through to Portland. Things 4 me are always busy. Need to slow down. I'll get n touch with you one these trip foo show Quote Link to comment
FrankenDime Posted January 4, 2017 Report Share Posted January 4, 2017 The 2nd pic is the 1st test fit of the comp mount... it ended up getting changed some... but it bolts to the KA factory ac mount All put back together with the outer dash vents used for ac ducts, and a quicky fabbed center duct. Do you have a ka24? How much did the entire set up cost you? I am looking to do something similar with mine. 1 Quote Link to comment
the510keeper Posted August 1, 2017 Author Report Share Posted August 1, 2017 Peanutbutter cups came over to Datsunville and detailed the shit out of the Fauxbird Then drove her 5 Quote Link to comment
the510keeper Posted November 16, 2017 Author Report Share Posted November 16, 2017 Have not done much with the rear of this little birdie, so the time has come. The plan custom A arms, upgrade LSD, Z32 rear calipers, and adjustable rear cross member with a larger exhaust hole Super light weight CV axle adapters Yummy 6 Quote Link to comment
the510keeper Posted December 15, 2017 Author Report Share Posted December 15, 2017 Been a long time with out my car. i use my car as a way out when having a bad day. U know get it go fast have fun This got installed of the Fauxbird to test it all out, I will be pulling all of this sub frame and installing it on my coupe, DaBird soon enough 6 Quote Link to comment
carterb Posted December 15, 2017 Report Share Posted December 15, 2017 looks really cool! What did you do for alignment settings? Are the inner mounts adjustable? Looks like I can see some bolts thru the crossmember to the front side? Quote Link to comment
