Busta Nut Posted March 16, 2015 Report Share Posted March 16, 2015 Get'er dun...... Quote Link to comment
the510keeper Posted March 18, 2015 Author Report Share Posted March 18, 2015 more pics to cum plasma cutting patch panels, we save everything we cut off over donors Rust holes = fugly New unrusted donor welded in Once blasted and the inside of this drain area is sealed we will be welding on this donor part 3 Quote Link to comment
the510keeper Posted March 18, 2015 Author Report Share Posted March 18, 2015 Opened the radiator hole 2inches or so all the way around, This car had the upper radiator support cut out, probably to remove the engine easier. plating the left hand drive stuff 5 Quote Link to comment
the510keeper Posted March 29, 2015 Author Report Share Posted March 29, 2015 Sexy boy and strip One real fucked up left quarter Raymond's been out doin himself, mayb I should of worded that different The car is also now blasted I wanted to do hood shocks but wanted ez off and on with the shock, so welded in the ball bolts 4 Quote Link to comment
the510keeper Posted April 4, 2015 Author Report Share Posted April 4, 2015 Making some progress with motivation from Tendril, and he's doing a great job himself Hood shock mod complete, fingers crossed Sealed the inner area of the drain area before welding in to place, with a weld through primer Camber plate mod complete Seam sealer Pretty 6 Quote Link to comment
datsunfreak Posted April 4, 2015 Report Share Posted April 4, 2015 Lovely. :thumbup: Quote Link to comment
Ranman72 Posted April 4, 2015 Report Share Posted April 4, 2015 you make it look so easy and I know it is far from easy Quote Link to comment
the510keeper Posted April 6, 2015 Author Report Share Posted April 6, 2015 More fun and exciting pics 7 Quote Link to comment
the510keeper Posted April 9, 2015 Author Report Share Posted April 9, 2015 On with the floors, usually we would do this before jambs but wanted to make sure jambs were done before headliner day. We have done this on a few cars welded in an extra nut for 3 point seat belts sealed 1 Quote Link to comment
the510keeper Posted April 9, 2015 Author Report Share Posted April 9, 2015 Then on with dull rub clear $100 a quart Danmmmmmmmmmmmmm before metal prep after metal prep bath Back from the headliner shop 3 Quote Link to comment
carterb Posted April 10, 2015 Report Share Posted April 10, 2015 Looking great James! Quote Link to comment
the510keeper Posted April 17, 2015 Author Report Share Posted April 17, 2015 Donor panel Quote Link to comment
the510keeper Posted April 21, 2015 Author Report Share Posted April 21, 2015 And thanks to Chris Metalguy541 Donor panel is a success Rear suspension time New ST rear springs cut down to 9.5inches LSD anyone yummi Thanks Tendril And made time to pick up my new hood for the beast 3 Quote Link to comment
Busta Nut Posted April 22, 2015 Report Share Posted April 22, 2015 LSD anyone yummi I'll take one......want BAAAAAD...... Good work fellaz!! 1 Quote Link to comment
the510keeper Posted April 22, 2015 Author Report Share Posted April 22, 2015 hours minutes 2 Quote Link to comment
q-tip Posted April 22, 2015 Report Share Posted April 22, 2015 Sooooo many louvers Quote Link to comment
Busta Nut Posted April 22, 2015 Report Share Posted April 22, 2015 Strip baby strip!! Quote Link to comment
datsunfreak Posted April 23, 2015 Report Share Posted April 23, 2015 What stripper are you guys using? If you know what I mean... B) Quote Link to comment
metalguy541 Posted April 23, 2015 Report Share Posted April 23, 2015 My fingers bleed just lookin at those louvers.... good call using that on the bare metal car Quote Link to comment
the510keeper Posted April 28, 2015 Author Report Share Posted April 28, 2015 Decided against flat clear 1 Quote Link to comment
the510keeper Posted April 28, 2015 Author Report Share Posted April 28, 2015 Using aircraft stripper on everything Quote Link to comment
metalguy541 Posted April 29, 2015 Report Share Posted April 29, 2015 Soooooooooo whats the new plan? I thought the flat clear looked great Quote Link to comment
the510keeper Posted April 29, 2015 Author Report Share Posted April 29, 2015 Gloss baby want grinder glimmer 1 Quote Link to comment
