Moisabamf Posted September 23, 2008 Report Share Posted September 23, 2008 when i turn the light switch to just parking lights, the car is fine. when i turn on the actuall front/back lights, there is a short. it has melted 3 of my accelerator cables at the most inconvenient times any suggestions/ spare accelerator cables i can buy? Quote Link to comment
ppeters914 Posted September 23, 2008 Report Share Posted September 23, 2008 when i turn the light switch to just parking lights, the car is fine.when i turn on the actuall front/back lights, there is a short. it has melted 3 of my accelerator cables at the most inconvenient times any suggestions/ spare accelerator cables i can buy? First suggestion is to fix it before you have an engine fire. :eek: The accelerator cables are melting because they're being used as grounds, probably for the 30A headlight circuit. The roadster folks are all too familiar with this issue. :( You need to check grounds and definitely the headlight circuit. Remove and clean all connections. Dielectric grease is your friend. Quote Link to comment
