cgovia Posted September 22, 2008 Report Share Posted September 22, 2008 is there an adjustment for the front of a 75 620 ,also where do you get the springs for the front drum brakes Quote Link to comment
lynchfourtwenty Posted September 22, 2008 Report Share Posted September 22, 2008 i think theres an adjustment.. pretty sure i adjusted mine when i had drums.. i know i adjusted the rears.. Quote Link to comment
datzenmike Posted September 22, 2008 Report Share Posted September 22, 2008 Behind the brake drum at the bottom of the backing plate is an oval rubber cover. Pop it off and inside is a star wheel adjuster that can be turned with a screw driver blade (if they aren't seized) Turn the wheel down to spread the brake shoes and up to retract them. I adjust till they just drag when spinning the wheel by hand, then apply the brakes to center the shoes and check and adjust again. Once they are just dragging with no change after applying the brakes I back off the adjustment one or two notches. Replacement spring hardware can be got at auto supply stores. Quote Link to comment
cgovia Posted September 22, 2008 Author Report Share Posted September 22, 2008 how hard is it to change to disc brakes Quote Link to comment
lynchfourtwenty Posted September 22, 2008 Report Share Posted September 22, 2008 well you either have to fabricate your own, or find someone to fab you some brackets.. the rest is cake heres my thread from when i converted mine.. http://forum.ratsun.net/showthread.php?t=1038&highlight=disc Quote Link to comment
Jester Posted September 22, 2008 Report Share Posted September 22, 2008 My parts truck has a set of disk brakes that I would like to put on my Hustler. I noticed the KC's have a "valve" of sorts under the cab on the pass side. Do I need to fit this to my Hustler to make the disc brakes work properly or is it just a matter of bolting them on? I noticed Lynch didn't mention anything about this. Nice write up btw. Quote Link to comment
lynchfourtwenty Posted September 22, 2008 Report Share Posted September 22, 2008 idk bout no valve.. an i believe its a porportioning valve.. not sure if i have one i never looked.. dont think you NEED it.. its for when you have a load in the truck it distributes fluid differently or something... remember.. the discs on the 78/79 trucks are different.. you have to cut an weld some crap an im sure theres a write up about it somewhere.. i didnt feel like doin that so i went this route.. oh btw you will notice i have a loss of steering.. i cant turn the wheels as far as i used to be able too.. only by a little but its annoying.. this is because the bracket is too long.. beebani did make a new style bracket but the set i got of those were warped somehow.. so i stuck with his old style bracket until i can make my own or have someone make me some brackets that will give me my full range of motion back in my steering.. Quote Link to comment
