afbrian13 Posted November 23, 2014 Report Share Posted November 23, 2014 I have a pretty nasty dent between my door frame and fender acrch on my 280z. Previous owner had it filled with way to much filler. To me i really need a spot weld dent puller, but money is an issue, as usual. Anyone gotten creative on this topic? I have a wire feed mig. I was thinking of tacking a wire, cutting the current and feeding a couple inches, then using a slide hammer with some sort of drill chuck to clamp the wire-assuming the wire/weld would hold. Also thought about getting some small bolts, tacking them all over the the dented area, and making a thread on slide hammer out of all thread and a weight. Either way its going to need a skim coat of filler. Cant get behind it at all for hammer/dolly because of the body structure. I just want to get it pulled as much as possible. Short of buying a stud gun, who has ideas????? Thanks! Quote Link to comment
afbrian13 Posted November 23, 2014 Author Report Share Posted November 23, 2014 Crap! Just realized i posted one topic to low! This was obviously meant for the body work section-sorry guys! Quote Link to comment
oakrun Posted November 23, 2014 Report Share Posted November 23, 2014 sell the wire feed welder and buy a stud gun? what i'de do is weld on some large washers. thread a cable into the washer eye and hook a come-along to the cable and pull the dent out Quote Link to comment
Dantheman Posted November 23, 2014 Report Share Posted November 23, 2014 If the interior is removed you should be able to access the back of the damaged area. Do you have any pictures? Quote Link to comment
afbrian13 Posted November 23, 2014 Author Report Share Posted November 23, 2014 I can get pictures in the garage later. Where the dent is on a z there is unibody structure behind it with 2 small (inch or two) access holes. I think i can get a wooden dowl angled through to tap some of the dent out. The washer idea isnt to bad! Thanks! Quote Link to comment
The Resurrector Posted December 7, 2014 Report Share Posted December 7, 2014 Suction cups work really good on larger dents, or you could tack weld some small sheets of metal, and grab it with a pair of vise grips. Quote Link to comment
