datsunfreak Posted November 16, 2014 Report Share Posted November 16, 2014 Anybody know what the "S/BRAKE" knob does? Quote Link to comment
datsunfreak Posted November 16, 2014 Author Report Share Posted November 16, 2014 Never mind. Found an owner's manual online. Apparently it lets you test and see if the brake light on the dash is working correctly. Guessing it failed a lot? :rofl: 1 Quote Link to comment
Mattndew76 Posted November 16, 2014 Report Share Posted November 16, 2014 that car looks as if it spent time under water Quote Link to comment
wayno Posted November 16, 2014 Report Share Posted November 16, 2014 It's a roadster, so your guess is likely right, no top in the rain, I call that under water. that car looks as if it spent time under water Quote Link to comment
datzenmike Posted November 16, 2014 Report Share Posted November 16, 2014 Never mind. Found an owner's manual online. Apparently it lets you test and see if the brake light on the dash is working correctly. Guessing it failed a lot? :rofl: The early 510 also had a button on the dash for testing the light. (below fuel gauge) 1 Quote Link to comment
datsunfreak Posted November 16, 2014 Author Report Share Posted November 16, 2014 that car looks as if it spent time under water Yes it does. Thankfully, not my car. :rofl: The early 510 also had a button on the dash for testing the light. (below fuel gauge) Cool! Need to go see if my '68 dash has one... Quote Link to comment
datzenmike Posted November 16, 2014 Report Share Posted November 16, 2014 lultz.. you don't know???? Quote Link to comment
Ranman72 Posted November 16, 2014 Report Share Posted November 16, 2014 68 510 CLUSTER IS THE ONLY ONE THAT HAD THAT BUTTON sorry for caps although the 69 speedo is similar it has heater control marks on the right side and the 68 does not Quote Link to comment
datsunfreak Posted November 16, 2014 Author Report Share Posted November 16, 2014 lultz.. you don't know???? The dash is in pieces in the back of the car. Has been ever since I got it. :rofl: Quote Link to comment
datzenmike Posted November 16, 2014 Report Share Posted November 16, 2014 68 510 CLUSTER IS THE ONLY ONE THAT HAD THAT BUTTON sorry for caps although the 69 speedo is similar it has heater control marks on the right side and the 68 does not I knew it was only the one year and assumed it was the '68. Duh... I now see the ignition switch Quote Link to comment
