mikeanike99 Posted November 10, 2014 Report Share Posted November 10, 2014 Would a brake booster from a 73 and up brake booster work in a 72 620? Quote Link to comment
datzenmike Posted November 10, 2014 Report Share Posted November 10, 2014 Technicall there were no '72 620s. All '72s were considered 521s. There were some 620s made very late in the '72 model year but they were lumped in with the '73s. The earliest 620 (I know of) was made in April '72. I don't know if the booster was the same for all years of 620 but.... In any case all L16 and L18 engined 620s (up through '74) had the same booster and master cylinder. I think the '75 to '77 were slightly larger master cylinder and the '78 and up were larger master again for the new disc brakes. Quote Link to comment
mikeanike99 Posted November 10, 2014 Author Report Share Posted November 10, 2014 The booster on my 72 620 tha was made in June is much smaller then the booster on my 78 620 Quote Link to comment
datzenmike Posted November 10, 2014 Report Share Posted November 10, 2014 March '72 to August '72 Car Number 000001-092941 would be a half year model. These half year vehicles are ignored and more or less included in the next full year which is '73. Most all manuals show '73 and up for parts and repairs. No mention of the '72 half year. Sept '72 to Sept '73 Car Number 092942-324000 is the '73 model year. Much later this changeover of model years gravitated to June/July. OK more precisely a 3/4" master cylinder was used from (mid'72) through '77 and then changed to 13/16" The mid '72 through '74 brake booster is the same part number. Later ones might work if you change everything you need. Quote Link to comment
mike Posted November 11, 2014 Report Share Posted November 11, 2014 Are the early ones the same as the B210 boosters or are the 210 smaller yet? FYI, The booster on my 74 and my brothers 72 look identical... It seems like there was a difference in the booster mounting between early and late 620s but I think it was just splined bolts on the adapter plate and all the dimensions were otherwise the same. Quote Link to comment
datzenmike Posted November 11, 2014 Report Share Posted November 11, 2014 The mid '72 through '74 brake booster is the same part number. Later ones might work if you change everything you need. The '78 and up booster part number is totally different and the master is also larger so it may be the same size and it might fit but it may have different internals. It might be stronger than the early one too??? Quote Link to comment
mikeanike99 Posted November 11, 2014 Author Report Share Posted November 11, 2014 i have everything from my other truck that i can swap over if it will work Quote Link to comment
datzenmike Posted November 11, 2014 Report Share Posted November 11, 2014 If you have everything from the pedal forward then it should. Quote Link to comment
mikeanike99 Posted November 11, 2014 Author Report Share Posted November 11, 2014 Ok Quote Link to comment
Charlie69 Posted December 5, 2014 Report Share Posted December 5, 2014 Mike were there disk front brake on any 77 model year 620s? Quote Link to comment
Pacific coast Datsun Posted December 5, 2014 Report Share Posted December 5, 2014 On my 74 620 i swapped on a booster off a 77 620. Bolted right up with no modifications needed. But...it does sit real close to the clutch master & when i ran the SU's i could not install the rearmost bolt on the air cleaner. Quote Link to comment
