BajaScout Posted November 9, 2014 Report Share Posted November 9, 2014 I have an electric fuel pump. The original mechanical fuel pump is still on the motor. Can I just remove it, or will something break if I run the motor without the mechanical fuel pump installed? 65 Datsun 320. Quote Link to comment
66Fairlady Posted November 10, 2014 Report Share Posted November 10, 2014 You can remove it and cover the hole with a plate. You will not break anything. Quote Link to comment
BajaScout Posted November 10, 2014 Author Report Share Posted November 10, 2014 Thanks. Looks like a BBC plate may work: http://www.mgexp.com/phorum/read.php?3,2285932 Quote Link to comment
MikeRL411 Posted November 10, 2014 Report Share Posted November 10, 2014 Don't forget a gasket! 1 Quote Link to comment
datzenmike Posted November 10, 2014 Report Share Posted November 10, 2014 Gasket?? On a chebby part?? It will never seal without a tube of RTV. Quote Link to comment
BajaScout Posted November 10, 2014 Author Report Share Posted November 10, 2014 Good advice. Thanks. Quote Link to comment
