tubbedbaggedstockfloored65 Posted October 17, 2014 Report Share Posted October 17, 2014 custom frame bagged stock floor body dropped 320 tubbed to fit 20s Quote Link to comment
tubbedbaggedstockfloored65 Posted October 17, 2014 Author Report Share Posted October 17, 2014 Will post pictures soon, Quote Link to comment
tubbedbaggedstockfloored65 Posted October 19, 2014 Author Report Share Posted October 19, 2014 Havin some trouble Quote Link to comment
tubbedbaggedstockfloored65 Posted October 19, 2014 Author Report Share Posted October 19, 2014 :( Quote Link to comment
tubbedbaggedstockfloored65 Posted October 19, 2014 Author Report Share Posted October 19, 2014 Quote Link to comment
tubbedbaggedstockfloored65 Posted October 19, 2014 Author Report Share Posted October 19, 2014 Wasn't much to look at , this is the first day on it way home Quote Link to comment
tubbedbaggedstockfloored65 Posted October 19, 2014 Author Report Share Posted October 19, 2014 First thing I did was bolt in dash after a quick patch job over stereo plate and took apart gauges cleaned them and put em back together and slapped her in , next I had to buy fenders nuts bolts and washers of all sorts and sizes to mount doors and all lock mechanisms Quote Link to comment
tubbedbaggedstockfloored65 Posted October 19, 2014 Author Report Share Posted October 19, 2014 Screwdrivered in wing window rubbers and put wing windows in along with side glass and door window framing , got the right bolts today mounted doors , blower unit, and got screws for dash tray and windshiel wiper motor motor and mounted that as well Quote Link to comment
tubbedbaggedstockfloored65 Posted October 19, 2014 Author Report Share Posted October 19, 2014 Mounted the stock truckj plate under hood after I got new bolts for hood structure and hood hinges and the mechanical arm that holds up hood , mounted door handles locks mechanisms and window cranks, and hooked up locks and put wiindows in and got them alined on rails and then crimped ruber seal around both doors Quote Link to comment
tubbedbaggedstockfloored65 Posted October 19, 2014 Author Report Share Posted October 19, 2014 Mounted my mirror and visors , doors ooen n shut nicely, found ignition need 2 have key made, Quote Link to comment
tubbedbaggedstockfloored65 Posted October 19, 2014 Author Report Share Posted October 19, 2014 [/url [url=http://s1379.photobucket.com/user/tubbedbaggedstockfloored65/media/20141013_115926_zps17acce7f.jpg.html] Quote Link to comment
tubbedbaggedstockfloored65 Posted October 19, 2014 Author Report Share Posted October 19, 2014 Had to drill new holes to mount feont headlights and had to grease up door hinges as they were rusted in place and as you can see fenders were cut and lengthened and brought up This truck had that dinky tugger sticker so I left it there and named the truck dinky tugger Quote Link to comment
wayno Posted October 19, 2014 Report Share Posted October 19, 2014 Once you add the photos, you can put any text you want between the photos themselves. So this doesn't look body dropped in the interior, so the frame rail top half was removed, correct? I see the inner fenders were modified also, did you do it, or was it done already when you acquired the truck? It doesn't look like the fender mod has been used to it's full potential, it looks like it was meant to be even lower, the only way you could get it any lower is to dig a hole and put the truck in the hole. For some reason I don't think the wheel is connected to anything, but it looks good. I will be looking forward to the progress on this!!! What engine are you planning to use in this? 1 Quote Link to comment
tubbedbaggedstockfloored65 Posted October 19, 2014 Author Report Share Posted October 19, 2014 Yes frame rail top half removed and its got little body spacers so it goes inch or so lower, and good eye the 20 inch rim just is sittin there not connected to anything, I have the front and back suspension just need 2 locathe few bolts and parts to put a arms together As for motor I have a stock 4 speed transmissiin and rear ed and driveline but I was gunna do l20b swap Quote Link to comment
tubbedbaggedstockfloored65 Posted October 19, 2014 Author Report Share Posted October 19, 2014 I was gunna do l20 swap and since I have back and front window I was thinkin about choppin top off Quote Link to comment
tubbedbaggedstockfloored65 Posted October 19, 2014 Author Report Share Posted October 19, 2014 I only thought about l20 cuz Its only spare motor I have except a vg motor that def won't fit, if I could locate en engine that would just bolt up I probably would do so but for now its motorless until I get compressor bags and valves and suspension parts and get it rolling Quote Link to comment
wayno Posted October 19, 2014 Report Share Posted October 19, 2014 I only thought about l20 cuz Its only spare motor I have except a vg motor that def won't fit, if I could locate en engine that would just bolt up I probably would do so but for now its motorless until I get compressor bags and valves and suspension parts and get it rolling A VG30 will fit, but it's an awful lot of work, I am the one who took the photos of it, it was tight, and the radiator was in the front. https://www.google.com/url?q=http://community.ratsun.net/topic/46269-30l-v6-l320/&sa=U&ei=GDZEVKnNBpKsyATEkILQCg&ved=0CAYQFjAB&client=internal-uds-cse&usg=AFQjCNFg2ECk6DZbkJ-7ta3iJ6M-s5gXVA He used a carb on his, although I think the 200SX EFI version would fit, but the wiring would be a nightmare unless you know what your doing. 1 Quote Link to comment
tubbedbaggedstockfloored65 Posted October 20, 2014 Author Report Share Posted October 20, 2014 I don't think I could handle the wiring for that, but an l20 yes I have motor and transmission I'm gunna set in and fet some idears yes idears Quote Link to comment
tubbedbaggedstockfloored65 Posted October 20, 2014 Author Report Share Posted October 20, 2014 Found bolts and screws to bolt on heater to dash bolted door handle mexhanisms drivers and passengees and more bolts to secure door window rails had to drill few holes and make new threads, and found a lock and snap ring for driver side, found 4 screws for windshield wiper motor that were mssin bolted the windshield wiper arm to motor and welded a bolt on passenger side wing window so it will swivel again and mounted the little break line unit under hood found more screws for door trim Quote Link to comment
