CaptunRatsun Posted October 14, 2014 Report Share Posted October 14, 2014 so im looking for a manual 5speed trans for my 510 can someone tell me which one is the easiest to swap and what from i may have found one but i want to make sure its right first Quote Link to comment
DanielC Posted October 14, 2014 Report Share Posted October 14, 2014 Easiest would be you searching this forum first. 2 Quote Link to comment
laotsu Posted October 15, 2014 Report Share Posted October 15, 2014 best to get an automatic three speed and add two gears and make it a manual. be sure to upgrade to aluminum or magnesium synchros 1 Quote Link to comment
tr8er Posted October 15, 2014 Report Share Posted October 15, 2014 What trans do you currently have Quote Link to comment
datzenmike Posted October 15, 2014 Report Share Posted October 15, 2014 You guys.... that any way to treat CaptunRatsun? If you have found one it's a little late to ask. A picture will help identify what you have from the at least four different 5 speeds I can think of that would bolt onto the engine you have. At the upper right of every page under the green 510 picture is our search engine. Type in dogleg swap into the 510 and start reading.... Easiest is the FS5W63A also known as a dogleg because of it's peculiar shift pattern with reverse above first. It's the same length as a 510 transmission, has exactly the same first four gears so no objectionable start off in first, uses the same speedometer cable and on the same side and can use the 510 clutch slave cylinder. I believe the shifter fits through the same floor hole. You will need to modify your transmission mount or better, just make one from a plan on the DimeQuarterly. Quote Link to comment
flatcat19 Posted October 15, 2014 Report Share Posted October 15, 2014 A real captain would have searched for the most covered topic in Ratsun history. Demoted. 3 Quote Link to comment
Guest Rick-rat Posted October 15, 2014 Report Share Posted October 15, 2014 You know your not allowed to say anything bad aboot Cannucks that don't know how to use the search function :sneaky: 1 Quote Link to comment
datzenmike Posted October 15, 2014 Report Share Posted October 15, 2014 A real captain would have searched for the most covered topic in Ratsun history. Demoted. Demoted to leftenant! Quote Link to comment
flatcat19 Posted October 15, 2014 Report Share Posted October 15, 2014 Demoted to leftenant! I see no user title change. Quote Link to comment
datzenmike Posted October 15, 2014 Report Share Posted October 15, 2014 That was directed at rick for the comment aboot Canadian pronunciation (did you 'get' it). Quote Link to comment
flatcat19 Posted October 15, 2014 Report Share Posted October 15, 2014 His title hasn't changed either. Not long ago I was a captain of something. Barely a one remains. Quote Link to comment
laotsu Posted October 15, 2014 Report Share Posted October 15, 2014 can I be a rightenant? Quote Link to comment
laotsu Posted October 15, 2014 Report Share Posted October 15, 2014 Demoted to leftenant! can I be a rightenant? Quote Link to comment
datzenmike Posted October 15, 2014 Report Share Posted October 15, 2014 His title hasn't changed either. Not long ago I was a captain of something. Barely a one remains. Smoke... you've evolved past clusterfuck. Quote Link to comment
flatcat19 Posted October 15, 2014 Report Share Posted October 15, 2014 Smoke... you've evolved past clusterfuck. Promoted. Quote Link to comment
datzenmike Posted October 15, 2014 Report Share Posted October 15, 2014 I think evolved. Promotion is bestowed on you weather earned or not. Evolved is a growth thing, wanted or not. Quote Link to comment
banzai510(hainz) Posted October 15, 2014 Report Share Posted October 15, 2014 77-79 200sx 1st gear is down left. Quote Link to comment
CaptunRatsun Posted October 15, 2014 Author Report Share Posted October 15, 2014 THANKS GUYS THERE IS A USED NISSAN PARTS PLACE WHERE I LIVE I JUST NEEDED TO FIND OUT WHAT THE TRANS NEEDS TO COME OUT OF TO MAKE IT WORK I HAVE AN L20B MY DATTO IS A 72 510 SEDAN AUTO ON THE FLOOR Quote Link to comment
Guest Rick-rat Posted October 15, 2014 Report Share Posted October 15, 2014 Do you need to shout?, eh Quote Link to comment
CaptunRatsun Posted October 15, 2014 Author Report Share Posted October 15, 2014 sorry lol Quote Link to comment
flatcat19 Posted October 15, 2014 Report Share Posted October 15, 2014 Auto? You should have way more questions than which 5 speed. Quote Link to comment
hosestop@msn.com Posted October 15, 2014 Report Share Posted October 15, 2014 Eh captain , the bad news is most people want a bit for a dog leg trans 300-500 , just wanted to let you down easy ,that's all. Quote Link to comment
datzenmike Posted October 18, 2014 Report Share Posted October 18, 2014 THANKS GUYS THERE IS A USED NISSAN PARTS PLACE WHERE I LIVE I JUST NEEDED TO FIND OUT WHAT THE TRANS NEEDS TO COME OUT OF TO MAKE IT WORK I HAVE AN L20B MY DATTO IS A 72 510 SEDAN AUTO ON THE FLOOR The Dogleg is the easiest but probably the rarest as only the early 200sx had it and it was an option on the '79 (only in Canada eh?) A10. The FS5W71B was an option on the '78-'79 620 trucks, the 78-'7 280z, '79-'83 280zx non turbo, the '80 710 2wd truck and the '78-'84 810/Maxima. May more of these were made and they are stronger and come in a variety of gear sets and over drive ratios. https://drive.google.com/folderview?id=0ByCvxnHNk90SYzc4N2E1MWEtMzg0MC00YTE4LTkxZGQtM2RjODA5ODA1YjU1&tid=0ByCvxnHNk90SMzIxZWIwYWYtYzljNy00ZGU2LWI3ODctYzRjMmE0MGY3NTA1&ddrp=1# Volume 11 issue 3 of the Dime Quarterly on Google Docs. Nissan Transmission Identification Guide. Teaser page... Quote Link to comment
