Charlie69 Posted October 12, 2014 Report Share Posted October 12, 2014 Here are some of the 520 model changes that I have verified from the single headlight 65-66 models to the 67 model. Of course the grill and double headlights Bed and fuel door shape change. (Sames as the 521) The fuel neck pipe still had the rubber grommet like the 65-66 models. (Not the 3 screw fuel neck pipe seen in the 521) I do not have a picture of it but I will post one later. The fuel neck pipe was totally different than the earlier 65-66 pipe. The tail lights have the back up lights added like the re pops on ebay. The doors are the same as the earlier 65-66 models that have the lock less vent window handles. this still door also has a rectangular notch on the inside top of the door where the went window is. Also has the same early style lock mechanism and striker plate on the jamb. you push the door handle forward to lock the door from in the cab. (I will post pictures later.) As Wayno noted in another post when I pulled the dash on this 67 truck the instrument cluster had the green turn indicator lenses was from another truck as it had a wrecking paint pen identification on it, all the 65-66 520 trucks I have dealt with had the amber turn indicators. The dash top was the 520 metal type black in color, but the dash face was black and textured not smooth like in the earlier 65-66 520 models. This dash face might have been from a later model truck also. Quote Link to comment
datsunaholic Posted October 12, 2014 Report Share Posted October 12, 2014 All 520s had amber turn indicators in the dash- my '68 520 does. 521s had green. My 68 also has a body-color matched dash face, with black top. The textured dash was a 521 thing. Quote Link to comment
Charlie69 Posted October 12, 2014 Author Report Share Posted October 12, 2014 I thought all 520s had color matched dash faces and the amber turn indicators. Living in AZ there just are not many 520 around. It is difficult to tell what the parts actually look like from the old parts and service manuals. datsonaholic does your 68 have the rubber grommet around the fuel pipe or does it mount with the 3 screws like the 521 fuel pipe/ Does your 68 have the locking wing windows? Quote Link to comment
datsunaholic Posted October 12, 2014 Report Share Posted October 12, 2014 If I remember I'll look, truck is 85 miles away. Pretty sure there wasn't a big change, grille is a bit different and it has a 1968 emissions sticker on the firewall. Quote Link to comment
difrangia Posted October 12, 2014 Report Share Posted October 12, 2014 Transmission was changed from the earlier top-loader to the bottom-loader with sheet metal pan in, I believe, September 65. Quote Link to comment
zed1 Posted October 12, 2014 Report Share Posted October 12, 2014 Possible changes (to be illustrated with photos at a later time) Fuse box changes from 6 lug to 10 lug Battery tray gains side angle supporting braces Passenfer inner fender gains tab for battery mount Driver inner fender drilled for waster bag Sunvisors changed from pressed perimeter edge trim to heat sealed edge. Keith Quote Link to comment
wayno Posted October 12, 2014 Report Share Posted October 12, 2014 Charlie, my 6/69 521 with a J block in it when I bought it doesn't have the locking wingwindow latches, they are the same as my 66 520. It also has the rubber grommet around the gas filler neck, it has no screws. I think I had the 521 taillights though, other wise I would have had a set of the narrower taillights around here, and I don't. I thought all 520s had color matched dash faces and the amber turn indicators. Living in AZ there just are not many 520 around. It is difficult to tell what the parts actually look like from the old parts and service manuals. datsonaholic does your 68 have the rubber grommet around the fuel pipe or does it mount with the 3 screws like the 521 fuel pipe/ Does your 68 have the locking wing windows? Quote Link to comment
datsunrides Posted October 12, 2014 Report Share Posted October 12, 2014 Full chrome turn signal stalk (no plastic tip) Square wheel wells in bed Hood emblem? Steering wheel? Glove box pull handle Quote Link to comment
DanielC Posted October 13, 2014 Report Share Posted October 13, 2014 I think the three screw filler neck was used in 521 trucks that had the evaporative emission vapor separator in the bed. I have four 521 trucks, build dates, 09/69, 01/70, unknown, and 4/70. Bases on serial numbers, the "unknown" was built possibly 3/70. The truck built 9/69, and unknown, have a grommet gas filler neck, and do not have evaporative emission control. The truck built 1/70, and 4/70 do have evaporative emission control, and the three screw filler neck. I think the 1/70 truck was originally sold in California, and that state required evaporative emission controls before the rest of the nation. Quote Link to comment
Charlie69 Posted October 13, 2014 Author Report Share Posted October 13, 2014 Great info guys. Keep up adding to it. These trucks are getting hard to find in AZ. Quote Link to comment
zed1 Posted October 13, 2014 Report Share Posted October 13, 2014 Charlie69, If there are at least four in Arizona, then you have double to population of Texas. Keith Quote Link to comment
XXL Posted October 15, 2014 Report Share Posted October 15, 2014 datsonaholic does your 68 have the rubber grommet around the fuel pipe or does it mount with the 3 screws like the 521 fuel pipe/ Does your 68 have the locking wing windows? My '68 has rubber grommet and locking wing windows. Charlie69, If there are at least four in Arizona, then you have double to population of Texas. Keith Now that I'm in TX, that makes 3? Or were you counting mine already? :w00t: Quote Link to comment
dat521gatherer Posted November 5, 2014 Report Share Posted November 5, 2014 There were 3 different glove box knobs for the 520. Quote Link to comment
dat521gatherer Posted November 5, 2014 Report Share Posted November 5, 2014 There were 2 different wiper knobs too. Quote Link to comment
dat521gatherer Posted November 5, 2014 Report Share Posted November 5, 2014 I've seen a rubber seat/boot mounted behind a 320 dome light? Possibly changed during the 520 run? I've only seen one or maybe two. Quote Link to comment
zed1 Posted November 5, 2014 Report Share Posted November 5, 2014 Now that I'm in TX, that makes 3? Or were you counting mine already? :w00t: You were in the count! Quote Link to comment
MikeRL411 Posted November 5, 2014 Report Share Posted November 5, 2014 Here are some of the 520 model changes that I have verified from the single headlight 65-66 models to the 67 model. Of course the grill and double headlights Added info - those front fenders will fit a 410 or 411 sedan if you can find a junk yard truck with decent fenders. Quote Link to comment
Driftteampower Posted November 24, 2014 Report Share Posted November 24, 2014 hi i need this part my friend TURN SIGNAL LF RF PICK UP DATSUN 1967 520 THANKS Quote Link to comment
datzenmike Posted November 25, 2014 Report Share Posted November 25, 2014 hi i need this part my friend TURN SIGNAL LF RF PICK UP DATSUN 1967 520 THANKS This is the 520/521 section, for discussion of our favorite trucks. If looking for parts please do so in out classifieds section... http://community.ratsun.net/classifieds/category/7-electrical/?sort_key=date_added&sort_order=desc There is a link near the middle top of every page marked CLASSIFIEDS 1 Quote Link to comment
