Kalani's '72 DIME
Kalani
  • Replies 638
Clutch needed a little moar adjustment......
.......threads on the rod were pretty mangled.....
9FD3B5C1-27CD-4948-BFB4-346434228CB5_zps
Clean up......
90B92BFD-EF5D-4C57-ADD9-DA1540AC4ADC_zps
....and cut the slot a little deeper......
34B47740-7224-4363-9D32-3171FCFAD145_zps
  • Like 4
I tried getting the studs in without taking the whole shit apart........
.....had to dismantle the brakes on the right side......left side was cake for some reason....all I had to do was take out the trailing shoe.....
4D59C158-9520-48DF-865A-A213527D474B_zps
Front....rear....new.....
484040B1-A333-46BB-A118-0A0DAFCEA119_zps
Front.....
B029DB95-8633-45E9-85FE-E83CFAED0B12_zps
Rear.....
7D843911-59E3-4C2C-8F0B-5BD2B465CA1B_zps
.....both have 8mm spacers......
How long did it take you to do this, really considering doing this for my car
Front and rear......minus beer and dabs......2hrs tops.....
......if the studs are any longer.....I don't think you'll be able to squeeze them in the rear......
It's weird you can use that type of lugnut i thought they all used the nuts with washers...
I was thinking the same thing..
I had the same wheels for a minute. And they needed the shank style with washer.
253254C3-31C4-4640-B262-5499782A5E03_zps
Lol when it was 4x4 status
Fronts you HAVE to split the hub and rotor. No getting around that. Rears, what Antony said. Why do you need longer studs? You won't have room for a spacer, unless you're going flared :D
did you make this or buy it?  i'm trying to get my side draft on and right now all i have is a hodgepodge of crap.
Pierce Manifolds in Gilroy, CA.......
Those are off the triple sidedraft setup I had on my Z that they sold me.....
..........talk to Stephen.....
http://www.piercemanifolds.com/
