Kalani's '72 DIME
Kalani
gonna need some gas in this after Kalani finished up installing the new hoses and tightened everything up
3556134D-9306-4E59-ACB4-4B0F122470B0_zps
Mike did a great job wiring in the fuel pump switch....... i didnt get any pics of it though  :crying: worked great and the fuel filter filled up right away  :thumbup:
1991CFA3-11A6-48F0-B6B9-D7598C714CA2_zps
coolant added, everything double checked and it was time to fire it up again.. needs busta's magic touch to get it all fine tuned but it close..
  • Like 4
  • Replies 638
Got everything tightened up and fuel in the tank last night......
.....skyblue wired in the fuel pump and no leaks were found when we turned it on......
Filled the engine with coolant and let it warm up last night....runs good......
..................annoying squeak is going on......
....hard to tell where it's coming from.....
Needs some timing and carb adjustments.......we called it a night......
Did anyone get video??
wow i was literally just tying the same shit... i got video but when i try to upload is says not allowed..............
Little googling shows 641-2785 is 45.5mm vs stock of 32mm.
Does that sound about right? Also are the  knurles the same size? did they fit right into the hubs?
Sounds right.....I didn't measure.....
...and yes.....they pound into the hubs.....knurls are the same size....
Would these work on 280zx hubs?
That is a good question......I don't see why not but I haven't tried.......
......I will try these on mine pretty soon.....
I don't even have a bolt for the pedal stop, or an actual pedal; just the rod. I like it. I can still heel toe fine. My friends trip out when they see just a rod.
I don't have an actual pedal either.....but I still have a stop......
.......don't wanna stress your linkage when you punch it...
I tried getting the studs in without taking the whole shit apart........
.....had to dismantle the brakes on the right side......left side was cake for some reason....all I had to do was take out the trailing shoe.....
4D59C158-9520-48DF-865A-A213527D474B_zps
787C7948-B88B-4422-8103-3E0C1902E2AF_zps
