Kalani's '72 DIME
Kalani
  • Replies 638
the homie kris, got to the shop and SKyblue had already started putting the lights back on and All I did was vaccum out the bullshit and hooking up the fuel line shiz
awwww yeeeeahhh gimme light baby!! Ratsun head light setup fasho
  • Like 5
I didnt take oics of the fuel pump setup last night!! Did you Busta?? haha scrubbbyyyyyy
edit*
fenders need to be rolled because I need to run spacers now due to the tie rod clearance after the bump steer spacers were installed. and longer wheel studs. fucky
edit* 2
whats the bolt pattern for 510s? 4 by 114 right? from what I found
CB9D4E93-14D6-4502-978C-4E52989C15B3_zps
Hey look it's a pic of Busta(?) taking the pic he posted.
7990B9FE-3A11-4D5C-844D-B3CDB02D4E91_zps
I'm actually pretty impressed how much detail I can make out on his phone screen :)
Car is coming along very nicely. Pretty quickly too. Great work!
Got everything tightened up and fuel in the tank last night......
.....skyblue wired in the fuel pump and no leaks were found when we turned it on......
Filled the engine with coolant and let it warm up last night....runs good......
..................annoying squeak is going on......
....hard to tell where it's coming from.....
Needs some timing and carb adjustments.......we called it a night......
Did anyone get video??
  • Like 3
